Question about Dryers
New dryer makes a loud thumping full or
New dryer makes a loud thumping full or empty...sears sent out a tech. and they said all whirlpool dryers do this
dryer is 2 mths. old
  • 220 Answers
Basically he was right but should have explained it to you,it depends on how bad the thump is,the drum has a seam (**** weld)where it is put together,as the drum turns the weld rolls over the rollers making the sound you hear.some are worse than others if it seems extremely bad call Whirlpool and see if they will at least try changing the drum once to see if it gets better.and ask for a different service company.They tend to not report such things to them so even if you have them out 3 or 4 times whirlpool will never hear about it.
Posted on Sep 03, 2009
  • 612 Answers
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
My new maytag dryer has a thumping sound when it runs, full or empty. it also has a rattle.
I am wondering if all packaging material was removed from the dryer. If you installed it yourself, please check through your manual and installation guide to see where packaging material may be located.
Dec 24, 2010 | Maytag MEDE500V Dryer
My whirlpool gas dryer makes a really loud thumping noise while it operates like rocks are in it.
Check the tub rollers and front seal on the tub.
One of the rollers has probably flattened.
Jul 19, 2010 | Whirlpool Dryers
I have a whirlpool model# LE5700XSNO that makes a
One of the drum supports has gone bad. Usually these come as a pair and are not bad to change.
Jan 26, 2010 | Dryers
Dryer makes a loud thumping noise when running
A thumping sound in your dryer could be caused by a flat spot on one of the drum support rollers. It can also be caused by a problem with the drum. An idler pulley on for the belt on the drive motor can also make a thumping noise when the dryer is running. Check to see if the cabinet is properly leveled with 4 feet firmly on the floor. Push down on opposing corners to check for play. Adjust the leveling legs if necessary.
Without a model number of your Whirlpool dryer, I am not able to provide much more help. If your dryer has the lint filter that pushes down into the top panel of the dryer, then here are a few tips for accessing the inside of the cabinet:
  • Unplug the dryer to disconnect electrical power.
  • Pull the lint screen out.
  • Remove the screws that secure the top panel to the lint screen housing.
  • Use a putty knife to release the clips on the front of the top panel (about 4" in from each side) that secure it to the dryer frame.
  • Hinge the top panel up and back.
This will provide to access to the inside of the dryer cabinet. Manually spin the drum in a counterclockwise direction and see if you can determine the source of the noise.If you need more help, resubmit your question with additional details and the full model number of your Whirlpool dryer.
Aug 08, 2009 | Whirlpool Dryers
Maytag front load dryer thumps while turning, empty, full etc.
If your Maytag is like my Maytag, there are two screws at the two bottom corners of the front panel. Once you remove both screws the front panel will lift out, up, and off. Then you can see what is going on inside.
Mar 28, 2009 | Maytag Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryer makes a thumping sound like it is out of balance.
if it is less then 6 months old you need to call whirlpool and they will send a tech out
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Loud thumping sound
It's probably time for new drum support rollers. There are two rollers the drum rides on and their bearings can fail, which makes them noisy and also makes the drum wobbly while it turns. Replacing the rollers isn't difficult, and you can do it yourself if you feel comfortable working with hand tools and are patient.
Here's a good site with information on belt replacement and other repair tips, and a source for parts:
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 63942 Dryer
Dryers Logo
254 people viewed this question
Top Dryers Experts
