Trane split air conditioning -XIL 14 MODEL- no cooling , condenser unit blowing cool air, compressor comes on once after start up and then dont't come on after that , condenser fan working
    Problem Solver:
  • 14 Answers
Shot of freon or loose signal wire between condenser and wall unit
Posted on Sep 03, 2009
  • 128 Answers
Check the compressor temperature if hot check refrigerant charge is less.
Testimonial: "this was a good troubleshooting step"
What's your question?I have a 2ph west point split air condition, the compressor is starting and gas inside the unit but it is not cooling.
Kindly check outdoor unit fan motor is running and condenser is clean . hope after this check and found all is working will solve the problem
Aug 10, 2016 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Outdoor fan does not come on
most likely it the the cap that is bad. Is this in heating or cooling mode?
Jun 03, 2010 | Heating & Cooling
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Oct 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
May 07, 2009 | Heating & Cooling
Heating & Cooling Logo
280 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
