Question about Car Audio & Video
Radio accessory power missing. Clock and 6 stack CD player still works, fuse in engine bay OK.
  • 291 Answers
How about fuses inside car
Posted on Sep 04, 2009
My radio/ 6 disc CD player.
Both. Check the power line that is supposed to power the clock and memory circuits when you turn off the ignition.
And your player has lost the ability of the laser to focus on the disc - hence the error message.
Sep 09, 2016 | 2009 Hyundai Sonata Limited
Which fuse is the cd player in the fuse box
One circuit is constant power to keep the clock and station pre-set memory maintained. The other is for the radio in general. If the clock works, pull both radio fuses and put them back in one at a time to see which one is constant power. If one of them is blown, you can usually see the wire inside it is burned with a gap. I don't believe there is a separate fuse for the CD player apart from the one for the radio. If the radio works but the CD player doesn't, I'm guessing it's an internal problem.
Jan 27, 2014 | 1994 Dodge Dakota Club Cab
Cigarette fuse
in the fuse box.
all fuses are covered in the operators guide, in the glove box.
lost? you should get one, so if one blows,, far from home, and stranded???/
in the box 2, in drivers cab (not engine bay)
use #25
clearly marked Cigar,radio ( clock , mirror , accessory socket )
if radio works, its not the fuse. bad lighter.
Dec 02, 2013 | 2000 Suzuki Grand Vitara
Radio, CD player, Sync, clock stopped working on my 2008 Ford Explorer
Most likely a fuse. If your fuse box is labeled it will say radio under the fuse. If its not check your owners manual for location of fuse box and radio fuse.
Mar 04, 2013 | Cars & Trucks
My car radio,cd,tape player and clock does not work
hi margie, your fault lies with the power line feeding both your clock and car radio units. check the fuse of the line feeding your radio/clock section. the fuse box should have the areas clearly marked. also check if the ground connection to radio/clock is not diconnected sumhow. if this advice does not help then it wub advisable for you to consult with nearest auto-elecrician. cheers.
May 22, 2012 | 2000 Ford Windstar
I'm looking for the indash clock wire connection for my 2000 Toyota 4Runner. I would prefer a photo. I was working on my aftermarket radio CD player and reinstalled it. The clock was working before that.
There is 1 fuse for the clock: If your audio system is working then that fuse is OK (instrument panel 18 15 amp fuse). Check it out just to be safe, you never know. If the fuse is OK then the clock itself has gone bad. I've heard of this happening after radio installs, no idea why. Anyway, I have clock removal instructions at www.autoclockrepair.com. I also offer a very affordable repair service with a lifetime guarantee.
Jun 05, 2010 | 2000 Toyota 4Runner
Heater will not work. Blower will not come on. Checked all fuses they seem to be ok.no power at blower resistor also the radio and cd player will not work Is there a relay for asseroies
Did you check the fuses by eye or measure the voltage with a meter? There may be a separate fuse panel in the engine compartment as well as in the interior. Look for a fuse marker Accessories too. The blower, radio, etc are controlled by the access. circuit.
Feb 06, 2010 | 2005 Suzuki Reno
The battery went dead in my 2005 nissan altima, replaced battery now my clock or radio wont work.
The clock & radio usually share the same accessory fuse.
1. Check the 10A Radio/accessory fuse in the cabin fusebox and replace if blown.
2. Check the fusable links from the + (red) battery cable to ensure they're ok and secure.
3. Check accessory relay, in engine fusebox.
Please advise outcome...
Nov 12, 2009 | 2007 Honda Accord Sedan
2006 grand cherokee cd player dont work
There are two power sources for your radio...one is full time and powers the clock, the other is on the accessory side...only hot with key on. check that power supply. Remember...fuses dont wear out...they blow for a reason. If you find a faulty fuse replace it...if it blows again, it is because there if a fault somewhere.
Aug 08, 2009 | 2006 Jeep Grand Cherokee
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
