Question about Garden
Where is the hydrostatic filter located on a JD 330 lawn tractor?
  • 22 Answers
There is none sealed unit if whining are slow pump inside going out purviservin@gmail.com
Posted on Sep 04, 2009
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What oil do I use in my ***** hydrostat?
Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like mobil). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Many of them are made by the same manufacturer. Tuff Torq makes a lot of them. They definitely make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, a lie. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. It's quite likely they made your tranny too.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black plug on the top. You have to remove the tranny from the mower (not a difficult things to do, takes about 30 min). Pull that black plug and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out, clean it and replace it. It may fall out while the tranny is upside down. When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Sep 25, 2014 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Why does my jd 4240 power shift **** when shifting
change fluid in your hydrostat and filter ths look for bad check valve for trans my have to take 100.00 to 200.00 to fix
Aug 31, 2014 | Garden
Murry model42591x92a hydrostatic automatic transmission what type fluid video how to put it in
Not Serviceable?? Don't you believe that story.
Hydro static transmissions on most lawn tractors are very similar. Many of them are made by the same manufacturer. Tuff Torq makes a lot of them. They definitely make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, a lie. All of the JD hydros are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. It's quite likely they made your tranny too.
Additionally, I have found that the manufacturers fill them with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Aug 24, 2014 | Garden
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Aug 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I stop my blades from hitting each other on a John Deere D 110
If your blades are hitting each other then you have the wrong sized blades. Each blade should be 21 3/8" long. This is the JD part number for the correct blades. GX22151
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 18, 2014 | John Deere D110 19.5HP Single Cylinder...
Where is the hydrostat transaxle and filter located on my murray 17.5 ohv riding mower
the filter is internal on riding lawn mower garden tractors have external filters
Jul 14, 2012 | Briggs & Stratton Garden
My JD L110 keeps vapor locking. I replaced the plug, battery, air and fuel filters. Could this be electrical?
Try this.
The next time it is running and begins to stall, loosen the fuel cap.
If that helps, clear any vent holes on the cap.
Good Luck.
Gary
May 01, 2011 | John Deere 22HP Hydrostatic 42" Riding...
What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Jun 24, 2009 | Garden
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
