Samsung hd tv will not turn on red led light blinks
Just wanted to confirm the solution (or atleast solution to MY problem).
Thank You to those who posted the solution to this problem.
I have a Samsung 52" HD LCD TV. I bought it 1 1/2 yrs ago and recently had been experiencing this problem of continual clicking and no video upon power up.
It would take approximately 3 - 5 minutes before eventually turning on. I noticed that prior to turning on, the clicking would get faster and the blue light at the base of stand would begin to get brighter.
So, based on the suggestions here, I opened up the back of the TV and located the Power Supply. I visually inspected the capacitors and in fact, found 2 of them that had a subtle but obvious bubble or protrusion on the top -vs- flat tops, like the majority of the caps.
These caps were 2200microfared, 10V rating. I went to my local Radio Shack and bought a higher rated version of the 2200 microfared caps (35V). I Replaced the old caps with these new ones and it solved my problem. :)
There were a couple of caveats though:
1) the higher rated caps were physically larger & had axial leads vs radial leads.
2) The leads of the larger caps were just thick enough to prevent them from being inserted in the board.
3) Rather then make the holes of the board bigger and risk destroying the solder pad, I used appropriate sized leads from some resistors that I had as extensions and soldered the new capactiors to the extensions. Of course you need to be aware of polarity and assure that the leads will not come in contact with each other or anything else on the board.
4) Capacitor Radio Shack p/n: 272-1020. Total cost of both was less then $10.
Hope this is helpful. I did take some pics of the capacitor location and board location. If anyone would be interested in the pics, you can email me @" me_n_bigbertha@yahoo.com"
Posted on Oct 13, 2009
  • 59 Answers
Look at the capacitors on secondary side of power supply as ripple on dc rails will cause this type of fault if you dont have a oscilloscope handy and there is no obvious blown caps then check supply voltages is in range.
Posted on Sep 03, 2009
Samsung UN55FH6003FXZA won't turn on even though the red LED on the front is lit showing power is available. It did have a long delay to turn on, now not at all.
Samsung TV won't turn on + blinking red light (explained fix ...
? 4:03
https://www.youtube.com/watch?v=wEWzYLaKdgU
Aug 29, 2014 - Uploaded by Mysimplefix
(CC) (HD) A step-by-step repair video, showing the replacement of swollen/shorted "electrolytic capacitors ...Missing: un55fh6003fxza
bout 1,270 results (0.53 seconds) Search ResultsSamsung LCD TV LN32A330 power won't turn on - Forums - CNETwww.cnet.com > Forums > SamsungCNETMy 1 1/2 year-old LCD TV model LN32A330 won't turn on by direct and remote today. The red stand-by light is lit, but never blinks and the TV won't power up. A..Samsung UN55FH6003FXZA BN94-06418R Main Board ...www.shopjimmy.com/samsung-un55fh6003fxza-bn94-0641...ShopJimmyThis Samsung UN55FH6003FXZA BN94-06418R Main Board IC901 EEPROM ONLY ... TV won't turn on after being off for 30+ minutes - TV shuts off by itself
Jan 05, 2016 | Samsung Televison & Video
Samsung LN46A580P6F LCD HD TV is turning on and off from two to ten times before it stays on when the tv is cold
Samsung LN46A580P6FX
On the main board, IC104 (Part #SPX1587AT) is a 3.3VDC to 1.8VDC regulator. When this IC fails, the 1.8VDC drops substantially when the TV is turned on. After five minutes or so, the unit operates fine. This IC can be purchased from digikey for about $1.80.
Another fix is to attach a 1000uF 10 volts capacitor from ground to the DC source of this IC. I used a 1000uF 50V (overkill) for proof of concept. See attached pictures.
Dec 17, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Samsung led tv troubleshooting guide
i have 65 inch samsung tv LED UA65D8000XN if you plag in red light on if you tuch power ON was blinking then the blinking it will stop but the tv will not turn ON the tv no display no picture relay click about once per second but the tv will not turn on thanks for any solution
Aug 22, 2012 | Televison & Video
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Apr 09, 2010 | Samsung LTM1755 17 in. HD-Ready LCD...
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
1,373 people viewed this question
Top Televison & Video Experts
Electro Med Services...
