Question about Samsung 226BW Monitor
Hello. My Samsung monitor, model no.226BW, wont turn on for some reason. No light is appearing at all, on the button or on the screen. Tried changing the power lead too but it doesn't seem to be the problem.
  • lorenzo carolus May 11, 2010
    check the power cable.try to plug the monitor into another pc.let me know if it works.
  • 8 Answers
SOURCE: Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Posted on Nov 07, 2008
  • 1684 Answers
SOURCE: Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Posted on Jun 17, 2009
benwabnick
  • 2404 Answers
SOURCE: samsung syncmaster 226BW no backlight
Look for any bulging capacitors, instead of a flat top they will look "pregnant".
If you see any of those then replace them with capacitors of the same UF rating and the voltage needs to be either the same or higher.
If you dont see any bulging capacitors or burnt parts, then its got be the LCD at that point thats not staying on and the cost to replace the LCD is as much if not more then to just get another monitor.
Posted on Aug 27, 2009
SOURCE: Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Posted on Feb 04, 2010
budmrtn
  • 11361 Answers
SOURCE: Monitor Flicker Samsung 226BW
Look for bad caps in the power supply just like all the failed SAMSUNG as shown here: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 06, 2010
Plug it in and all you see is white screen
There are two problems, microprocessor controller not working properly, and the LCD panel is defective, replace the video cord from the computer to the monitor if possible just to rule out the screen issue, if no change! I recommend replacing the item due to cost over runs to repair.
Mar 27, 2012 | Samsung 226BW Monitor
Samsung 226BW screen takes a long time to show anything
This model may have defective capacitors in the power supply. I normally replace the 2 or 4 bulging caps and normal function is restored.
Monitor Mike
Apr 20, 2010 | Samsung 226BW Monitor
Aug 26, 2009 | Computers & Internet
Problems with a samsung 226bw lcd monitor
This problem may be due to various reasons. I advise you to visit a service center. they will replace the faulty part,( You may call them and explain them by giving the serial number and model Code).
Jun 29, 2009 | Samsung 226BW Monitor
Hello cstafford35,
Buddy
Corporate Computer
Jun 17, 2009 | Samsung 226BW Monitor
1of 2 monitors wont turn on
Frostbane is correct. I called 1-800-SAMSUNG to report the same problem and they are going to send me a replacement display.
Mar 24, 2009 | Samsung 226BW Monitor
Problem with Samsung SyncMaster 226BW
Click the top button on the side of the monitor to open the monitor's settings. In the "Picture" Settings, scroll down to "MagicBright" and open those settings. Chances are you have it set to "Dynamic Contrast". Switch that up to any of the other settings and then it won't try to adjust the gamma based on what is on the screen.
Hope this helps, I struggled with the same problem for quite a while until I found this setting.
Feb 19, 2009 | Samsung 226BW Monitor
Samsung 226BW won't turn on until a few minutes.
This is an indication that the power board in the monitor is bad.
Mar 02, 2017 | Samsung 226BW Monitor
Movie on monitor
Hi, Normally I would suggest that you first lower your laptop's screen resolution, refresh rate and color quality and verify that you have enabled the external monitor or dual view in your Display Property Settings as well as the Fn key + F?. However, this kind of problem should not exist with an LCD Widescreen monitor with specs and features as your Samsung 226BW. If trying the reco on the first paragraph and you still have no movie display (but all other laptop display shows), perhaps it is a problem with the Samsung 226BW. To my knowledge, this particular brand/model uses no less than 3 different panel display, some not as good as the others. Verify that you have an original Samsung panel display in your Samsung monitor by looking at the sticker at the back of the screen, it should say Model: 226BW [R] S. If it says A or even a C, then perhaps the display panel is not living to its specs/claimed capacities. You of course can request a replacement from your dealer and cite your problem but insist that it be an "S". Most instances (but not always) an "S" would mean panel screen by Samsung, "A" by AU Optronics and "C" by CMO. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | Samsung 226BW Monitor
Window screen problem
I'm guessing you may need to download the proper software and drivers for this monitor. Have you always had this problem and now want to change it? Try this website: http://static.tigerdirect.com/pdf/samsung-206bw-manual.pdf
Jun 21, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
243 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
