Question about Baby Lock Evolve
Screwdriver for my overlocker machine
I have same problems with mine one of the needle broke so i needed to remove the lil **** left in so i misplaced the lil screw driver somehow and i am finding it hard to find such lil screwdriver in shops. i love my machine makes sewing so easy
xxx
    President:
  • 2,976 Answers
Home Depot has a fantastic small screwdriver. It is a Husky number HD-74501S. It has standard and phillips points, ranging from 1/16" to 1/8". There are 4 tips and 3 store in the handle. It costs less than $10.
Posted on Sep 03, 2009
Husky 910 overlocker..left needle will not sew stitches...does not unthread just won't form stitches
Be sure to install a brand new needle. Verify it is the correct needle for your machine and it is installed facing the correct direction.
Remove all the thread from your machine. (Clip the threads below the thread spools, RAISE the presser foot, and gently pull all the threads DOWN through the needle--NEVER up!)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify that you are threading each thread in the order specified in the manual--failure to do so will cause your machine to malfunction.
When threading, give each thread an extra little tug when going through the tension disk.
Set all the tensions to the midway point for a 3 or 4 thread overlock.
Test your machine.
If the left needle still fails to stitch, then your machine may need a timing adjustment.
Apr 24, 2017 | Sewing Machines
Replacing needle on Singer overlocker.
The manual should have instructions. Most overlocker needles have a screw that holds each needle in place. Just loosen the screw with the screwdriver that came with your machine, slide the old needle out (note which direction the flat side of the needle is facing), insert the new needle as far up as it will go, and tighten the screw. Don't lose those screws or drop them inside the machine. If you remove a needle so you can serge without it, be sure to tighten that screw so it doesn't fall out.
Mar 02, 2017 | Singer Sewing Machines
I have just snapped the needle on my Husqvana overlocker 905 how do I change the needles
The serger came with a tool just for that purpose. It may be a small screwdriver or it might be a hex or Allen wrench. Locate the screw that holds it in, insert the proper tool and turn counter clock wise until the needle will slide down, remove and replace with new needle, then tighten, clockewise the screw. You are done
Jul 05, 2014 | Sewing Machines
M546 brother overlocker
it's possible that when the left needle broke, it could have caused a missalignment in the machine, it would be a good idea to have the machine checked.
Nov 09, 2013 | Brother Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
Left needle thread is too loose on toyota overlocker
check to see if the needle is inserted correctly
make sure it's the right needle for the machine
try adjusting the tension setting to a higher number or letter
if that doesn't work, I suggest taking the machine in to be checked
Jul 29, 2012 | Toyota SL3487 Sewing Machine
I have a Singer Ultarlock 14U34 and need to know how to adjust the stitch width.
You can download a manual from this link
http://www.singerco.com/uploads/download/664_14u34b,234b.pdf
Check page 16, changing the seam width is done by moving the cutting blade left or right and using only one needle. So if you want the narrowest seam, use the right needle only, remove the left one, and move the blade as far left as you can. Your manual says to turn machine off at the wall for safety, many overlockers will have a motor cutout when you open the front covers, but its good practice to turn off too. Then you put pressure against the upper moveable blade and swing it up out of the way and make adjustment to the lower fixed blade with a screwdriver in your kit (some overlockers it is a knob you move to move the blade position).
And reverse for a wide stitch, use left needle for 3 thread wide seam, and move the blade far right.
You can also use the 4 thread seam where you use both needles and trim up narrow but the seam will be heavier than a three thread.
Each time you make changes to the amount of fabric being trimmed, you may need to finess the upper and lower looper tensions to ensure the seam is tensioned enough to just meet on the cut edge of the fabric. This is the norm for overlockers, each fabric will behave a little differently so you need to test stitch and adjust a little. Your manual will explain this process too.
Sep 05, 2011 | Singer 14SH654
I have a husky lock 234D serger and no manual. how do i use 3 thread overlock? which threads do i use?
To use a 3 thread overlock, thread the overlooper; the underlooper and then use ONE of the needles. Removing the RIGHT needle will produce a 5mm or 1/4" seam. Removing the LEFT needle will produce a 3mm or 3/16" seam.
Dec 17, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
122 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
