Question about Brother MFC-260C All-In-One InkJet Printer
My Brother MFC-240C won't print the black ink. I
My Brother MFC-240C won't print the black ink. I have cleaned it many times and even changed the cartridge. Help!!
  • speedyalexis Jun 10, 2010
    Hi, I was the one who posted this problem. I have found a solution! I changed the printer settings for the paper. Instead of the plain paper setting, I switched it to inkjet paper. It works well with the color and / or greyscale setting, but the black is darker with the greyscale setting. Hope this helps...it took me months to figure this out.
    Thanks dekinl, but nothing worked.
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
My Brother MFC-240C printer is causing me grief. It prints out in black as though it is out of black ink but the ink is full. The other colors print out ok. Any thougths?
If the colors print OK, you could try cleaning the black nozzles. (Your machine may allow you to clean just the black or the colors, or all the nozzles).
1) Press the <Ink> or <Ink management> key
2) Use <Up> or <Down> arrows to navigate to "Cleaning" and press <OK>
3) Use <Up> or <Down> arrows to navigate to color that needs cleaning, or "All" and press <OK>
4) The display will show "Cleaning" and "Please wait"
5) After completion, the printer should be ready
If the problem persists, brother advises that you may need to repeat the process up to four times. If still no results, contact brother customer service.
Jan 22, 2010 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink does not print on brother 240c
If you haven't changed it recently, it may be out of black ink. The product code for Black is LC51BK.
Brother's supply site
Dec 10, 2009 | Brother Multi-Function Center MFC-240C...
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother Mfc 240c will not print using black ink... cleaned and reinstalled ink cartridge that is full, but has been refilled. Any chance this is an easy fix issue?
we can refill 100 times but it woks.probly refiling methood is mistake. one time pul out all ink and gas of cartage by sering.and reffil again.
Oct 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Black ink not printing even after changing the ink twice
try to clean the printhead or the cartridge by wiping it in the wet cloth...
maybe the nozzle of the black cartridge suffered clog..
you remove the clog by wiping it...^_^_
I hope it will solve you problem..
May 12, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-260C All-In-One InkJet Printer Logo
1,041 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
