Question about Whirlpool Water Heaters
Can i convert a whirlpool water heater from propane to natural gas
  • 20 Answers
I would recommend to contact the manufacturer. There are certain model of water heaters that cannot be converted at all. The technical support line can answer your question on this. Please have your model, product, and serial number when calling 1-877-817-6750.
Posted on Sep 04, 2009
  • Whirlpool Master
  • 6,674 Answers
Normally yes, change of orifice instructions are quiet often tagged and in a bag somewhere on unit, with instructions, but I highly recommend someone licenced to perform the switch over, as obviously it's not something to guess at, and shouldn't cost much to do. If you contact whirlpool with model & serial number , they may give you instructions, or at least the nearest service person in your area. Remember, have it done by a competent, certified technician please!
Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
May 06, 2015 | Water Water Heaters
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
Sep 13, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Can 42v50- 36pf be converted to natural gas ?
You would have to inquire of Rheem. Some appliance manufacturers have conversion kits available
Mar 24, 2013 | Rheem 42V50-36PF Professional Propane Gas...
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
Change orfis in water heater
Do NOT do that.
If you put LP gas to NG heater you can cause explosion.
Contact manufacturer and see if they sell conversion kit. Most do not.
Copy following link for general overview and cautions:
http://waterheatertimer.org/pdf/Convert-Natural-Gas-water-heater-to-LP-heater.pdf
Jul 11, 2012 | Water Heaters
CHANGING AN ORFICE
This unit cannot be converted from gas type to gas type.
Feb 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Water Heaters Logo
248 people viewed this question
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
