Question about Maytag MSD2756G Side by Side Refrigerator
WATER COMING OUT FROM THE FREEZER SIDE - Maytag MSD2756G Side by Side Refrigerator
  • 220 Answers
You most likely have a clogged drain,turn off or unplug the unit Remove the shelves a racks from the bottom half of the freezer section You'll see a metal panel at bottom  at the top of this panel are two screws,remove those and tilt up the plastic panel so you can remove the bottom panel.
 Once that is out of the way you'll see Ice built up in the drain trough at the bottom don't poke around with anything sharp but you can tap the ice with a screw driver handle and break it up for removal,once the ice is removed pour a cup of hot water into the trough to thaw the drain,when it thaws the water will run into the pan under the unit and evaporate
Posted on Sep 03, 2009
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water is overflowing at the bottom of the freezer
Blocked drain line for when the freezer goes into defrost.
Apr 30, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
Water leaking under freezer side
Hi, is the leak coming from the hinge on the freezer door? Do you have ice building up inside the freezer section?
Please let me know
Vic
May 31, 2009 | Refrigerators
No water coming from dispenser on Maytag MZD2766GE
You should defrost the freezer. The water line coming into the freezer is frozen and the water can't get through the little tubing.
Feb 01, 2009 | Maytag MZD2766GES Side by Side...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
82 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
