Question about Car Audio & Video
My ford ka has a cd stuck in it with error code e11 showing. Help?
  • 4,848 Answers
According to the Ford Audio Guide error E11 is "SPI BUS FAILURE" and Ford recommend "Check and repair the wiring harness "
I suspect that the error message will be because of the jammed CD.
You can possibly tease the CD out through the slot  using another (old) CD.
Failing that , remove the player from the dashboard, take off the cover and release the jammed CD
Make sure you have the Security Code before pulling it out of the dashboard
Posted on Sep 04, 2009
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Ford KA 1996 CD player displays "error 2"
take it to a ford dealer or replace it with a used unit -cheers Denny
Jun 04, 2013 | Vehicle Parts & Accessories
E11 error code fios motorola box
Eb 11 - Invalid unit address / Resettable only at factory / Replace the DCT
Here's a site with a list of fault codes:
How to use Motorola DVR Boot Error Codes
Mar 31, 2012 | Motorola Televison & Video
Cannot play the cd and displays error e-11
Error Code E11 is "SPI bus failure" the correction is "check and repair wiring harness" if OK "replace audio unit" this from the Fords workshop manual.
Hope helps (remember to rating this free answer.
Oct 07, 2011 | Car Audio & Video
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Hi I have a Ford 5000C radio cassette a Visteon i change car party and the sound become too week can you help me thanks
SALAMORALAYKOUM FRERRE CODE FORD VISTEON IN PORTUGAL E11 10R-020339 V.C.A e11 020339 PART N3S4T-18k876-DA SERIAL n M172434
Sep 20, 2010 | Car Audio & Video
Have lost radio code for my Ford KA - 6000 CD serial number MOO1984
Your Code is : 6639
Ford  Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Mar 06, 2010 | OEM Systems Car Audio & Video
Car Audio & Video Logo
1,243 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
