The drum on my Kenmore front-loading washing machine has come loose and is rattling around. Is this a common problem and is there an easy fix?
    Problem Solver:
  • 14 Answers
Depending on the age or usage hrs could be loose nut from factory or worn bearings
Posted on Sep 03, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
When the machine goes into spin cycle there is excessive vibration as if something was loose in the drum. Other wise the machine cycles fine. Is there someway to check for bolts or nuts loose on the drum....
Move the drum around by hand and listen carefully. There should be no loose bits or rattling, if there are it is possible that something has slipped in between the drums. It sounds as if the drum bearing may be failing. Grip the inner drum and move it up and down at the front while feeling for play relative to the outer drum. i.e hold outer drum and lift inner drum relative to where you are holding. There should be virtually no play.
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
Something loose between the drums
how did the underwire get there, you may want to remove lower panel please unplug washer before removing panel use a flash light there is a area were coins and other objects fall in to also have a bucket there well be water in the lower unit use something to fish it out lucky it did not get caught in pump
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
Tub is loose in front loading machine.
If it is the main drum which is now sagging - rattly and loose - check rear screws are tight. If they are, then you probably need a rear drum bearing.
Cost is around £50 for the parts - and around 2 hours labour as it is a fairly long job to replace.
Sep 30, 2009 | Washing Machines
Washer is louder than normal The drum seems to
the bearing assembly is beginning to fail.
requires an overhaul.
this problem is far too common with Kenmore and frigidaire front loaders
Mar 24, 2009 | Kenmore 43042 Front Load Washer
Kenmore front laoder washer with loose wash basket
Highly likely that either your bearings or spider arm has gone out, this is no easy fix. You can 'search' above or click on 'troubleshooting' in blue to browse
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
