Question about Toshiba Satellite U305-S7477 Notebook
Charger -chirping noise
My charger, whenever plugged in to an outlet starts chirping.Even if i disconnect the wire connecting directly to the laptop; ( leaving me with the prong and the block)
When just that is attached to the block and has a source of power that it chirps repetitely.
The second its unplugged it chirps once more and then sound like a dying battery opperated toy.
  • kerrieanne Sep 04, 2009
    I was hoping it wouldn't come to that but oh well
    Any chance you'd know where I could possibly find one?
  • 20 Answers
It sounds like the capacitors in your charger are starting to give out. I would buy another.
Posted on Sep 03, 2009
  • ahmad hasan Sep 04, 2009
    I would try ebay, but first I would get the number off the one you have and look that way to make sure you get the right one.
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
Cozmo robot won't hold charge?
yes -we know about attachments
just try replacing the faulty batteries
Apr 21, 2017 | Miscellaneous
My Dell Laptop was working fine in 220V country, when i moved and try to use it in US (110V) the charger LED is ON but once i plug it in the laptop it goes off and the laptop is not working. i even tried...
So two different devices, each with their own charger, don't work in different power outlets in different rooms? How about if you plug a light into the same outlet. Does the light work? Does it dim when you plug the charger into the laptop? If so you have a bad electrical system, either a loose wire or bad outlet.
Jul 15, 2017 | Dell XPS M1330 Notebook
Hi my laptop charger is plugged in but battery is only on 6% and it says that it's not charging
try to connect the laptop directly to the power outlet,if it is still working,that means that the charger is not defective and its the battery that is encountering technicalities
Jun 19, 2010 | Computers & Internet
Hello my laptop isn't charging properly. It is plugged in and all of the cables are connected. There is power in the plug socket but it doesn't seem to be charging. Help!
Hi! Drain the power charges of the laptop by shutting it down and by unplugging both ac adapter (charger) and battery from the computer.
Press the power button for like 10 times while the battery and charger is disconnected to drain the power of the board.
connect back the battery first then connect the charger to the computer. Make sure that the charger is connected to a stable power outlet while charging the system.
Please leave a comment if you have any other questions.
Cheers!
Jun 10, 2010 | Computers & Internet
My Dell 1501 laptop turns off as soon as the charger is connected
Sounds like you have a multiple problem going on here honestly. If you have a constant light on your charger even when its completely disconnected from the wall outlet then your charger is bad for sure, cause the light shouldn't come on unless the charger is hooked up to power.
Your battery maybe shorting out the laptop which is why it needs to be taken out for a bit before the laptop will turn on.
My suggestion would be to try a known good working charger on your laptop to make sure it turns on properly and stays on without the battery hooked up.
Then if your laptop stays on for a while then with the laptop on and the charger hooked up, connect the battery again and see if the laptop will charge up the battery to 100%. If it does then disconnect the charger and see if the laptop stays on with just the battery hooked up. It could be that the battery is drained beyond 0% and just needs a good charging. If you can't charge up the battery or the laptop still turns off to where you have to take out the battery to get the laptop to turn on then the battery is bad and would have to be replaced.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
Dell laptop charger
First try starting the machine without the battery, only the charger, Then check the charger with an ohm meter to see if it's working properly. The out put readings are listed on the charger. In case of a surge, the charger is designed to go out first before damaging the system. However, this is not always the case. If the charger checks good, then you should take it in for a professional diagnostic because the problem may be with the power management system on the motherboard. One thing to keep in mind for future reference is when moving to a different location with your laptop, when unplugging the charger, always unplug the charger from the laptop before unplugging from the wall socket, and when plugging in, always plug the charger into the wall socket before plugging into the laptop. This will keep from surging your system.
Jul 16, 2008 | Toshiba Satellite A45-S250 Notebook
On my camera the battery charger light is blinking and the battery is not charging
Before you get creative and directly plug your batter into an AC adapter, try something much easier first. I have the same problem with my Olympus 770SW batteries. As silly as it sounds, the charger will only work in a select few outlets in my house that I found by trial an error, actually pure frustration. I suggest, go around your house and plug the blinking charger in all the outlets and see if you find one that works. That sounds a lot less shocking than solution 1 and 2 now doesn't it? Good luck!
May 23, 2008 | Cameras
Toshiba Satellite U305-S7477 Notebook Logo
1,338 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
