Question about HP Compaq ProLiant ML370 G3 Server
SCO UNIX ON CAMPAQ ML370 WILL NOT INITIALIZE. AFTER THE SMART ARRAY INITIALIZES, IT INDICATES I NEED TO REPLACE ONE OF MY RAID DRIVES. I HAVE TRIED REPLACING THE DRIVE AND IT WILL NOT MOVE PAST THIS POINT.
  • 922 Answers
Typically, you need to do more than just physically replace the drive.
You need to go into your RAID settings during the POST. Make sure the controller recognizes the drive and add it to the array.
If this helps please vote for my solution.
Posted on Sep 14, 2009
Install new OS
Use the HP Smartstart CD and configure the with array with 2 arrays and 2 logical drives. The first with OS array on RAID 1 (2 drives mirrored). The second array on RAID 5 (3 drives minimum).
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18964&prodSeriesId=345557&prodNameId=344318&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-bd347636805e4917a617382469
Make sure to use Insight Manager for worry free monitoring.
Oct 22, 2012 | HP ProLiant ML370 G4 Server
I have a Compaq Proliant ml370 G3 with an HP smart array 641 controller that I am trying to load SCO open server 5.0.6 on. This is tied to three drives in a RAID 5 config. When I try to run the Smartstart...
SSCD is not supported for the installation of SCO 5,6,7 or 8 you may need to create the arrays using ORCA at the bios of the 641 controller at post and then install SCO directlly from the installation cd.
To access ORCA press F8 or F9 when the smart array controller is posted at the bios screen
Sep 21, 2010 | HP Compaq ProLiant ML370 G3 Server
Unable to determine the boot device. Drivers may not be initialized. Initialize using the BIOS utility, or check if the disks are connected properly.
You need to go into setup view you drive array sounds like you may have one bad drive or the raid array has dropped by moving drives around hope this is what is wrong then re initialize the drive array you need more help email me at mje.bend at live dot com
Initialize using the BIOS Utility .
Nov 07, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Replacement HD for RAID Array
you have a jbod you will need to do this right click on my computer select manage from the drop down menue under this option you are going to select disk management on the lower right it will list the hard drive if installed correctly.Initialize the drive and format it .
Good luck
Aug 29, 2009 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Our sco unix server was shutdown dut to power failure,now when we turn on the server it ask for root file system floopy, is it possible to download rootfile system of sco open server 5.0
I think you will need the original disk for this - its going back a bit but I think this is a security disk that was created at install...I hope you've got it somewhere...
Jul 10, 2009 | HP Compaq ProLiant ML370 G3 Server
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
The system is setup using the RAID 5 config, now out of 5 drives it says 'OK' for 3 drives on 0, 1 & 2 and for 3 & 4 it says 'Replacement'. Is there any way of finding the correct Logical sequence...
Dont you have any levelling inside the machine? Go open and check.
When you have replaced the 2 defective drives with a new one, restart the computer and Raid 5 will automatically rebuild.
Jun 18, 2009 | HP ProLiant ML370 G4 Server
Harddrive array sequence causing system in booting
If the only drive you changed was the drive that failed and all the others are in the correct sequence, then that's a good thing.
The next question is, did you have this system setup in a RAID Array and if so, what RAID configuration were you using (RAID 0,1,5, etc.)? Some RAID configurations allow you to replace a failed drive and not lose data, but I will need to know more about how you set the system up in order to help you more.
Drive array problem
Hi Nick ,
As of now you can Select "F2" to accept data loss and re-enable logical drive. This Load OS Normally .
It seems that one of the HDD in the RAID 5 has failed , Did you notice any LED indications like red or amber on the HDDs ?? if so get that hdd replaced . Make sure the Failed HDD is replaced .
You can run the Array Diagnostic Utility from HP System tools to check the Failed Drives and also frimware version of the controller . If the frimware is not latest Update it from HP website. DL380 G4 should have Smart Array 6i controller .
Hope This was Helpful
cheers :)
May 17, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant ML370 G3 Server Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
