Question about Sony KP-41T65 41" Rear Projection Television
SONY KP 413SU CONVERGENCE
PLEASE CAN ANYONE TELL ME WHERE THE CONVERGENCE IC's ARE LOCATED IN THE BACK OF MY SONY KP413SU. I NEED TO KNOW SO I CAN FIND A PART NUMBER FOR THEM.
THANKS
  • Anonymous Jan 07, 2008
    I can conv the red up & down left & rt but my blue will not go up it goes left & rt thought
They are on a heat sink on the board as soon as you take off the back cover I think the # you want is stk392-150 75$ www.partstore.com
Posted on Dec 30, 2007
Hi!! my sony projection tv kp-51ws500 shows double picture. there is reddish outline & its out of focus. i need help to reapir this. please advise. thanks
This sounds like a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Sep 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Finding the convergence ic's
They are located on the D board attached to large aluminum heatsinks They have the numbers STK392-560 you will need to replace both of them. You can get new ones at this link and they will give you free installation instructions with free tech support to help you with doing the repair. here is the link.
http://servicemanuals.vstore.ca/
Apr 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Intermittently convergence problem.
Try resoldering both convergence ICs located on the D board if that doesnt correct the problem you will need to replace both ICs let me know if I can assist you further.
Apr 04, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-48V85 Sony with Technician diagnosed Convergence problem
kt33, of course you can do it yourself cheaper, IF you know how to solder & un-solder parts and IF you have a voltmeter and know how to use it. Convergence IC`s and probably a few support resistors will have to be removed and replaced. IF you can do the above I can look-up the IC`s for you but your on your own with the resistors until you tell me which ones you need if any, let me know, BMW Rider
Dec 18, 2007 | Sony KP48V85GRAY 48" Rear Projection...
SONY KP 413SU
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Dec 06, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Convergence i.c.'s
The convergence IC's and fuses are not your problem. If the Sony projection set has a bad convergence IC and/or a blown fuse or fuses in the convergence circuit, the set will continue playing but the colors will not line up correctly. If the set will not turn on at all, and has no lights at all on the front of the set, the problem is in your main power supply. If the set tries turning on and then flashes the timer LED on the front of the set, count the number of times the LED flashes, as that is the code for why the set is notworking. I have found that the most common cause of the set not starting is a shorted flyback transformer.
Sep 02, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
