Question about Fujitsu fi-6130 Flatbed Scanner
6130 will scan first time I press, but will not on second; must turn off and start again
    President:
  • 3,085 Answers
Open the front cover and make sure the feed switch actuator swings freely.
Posted on Sep 05, 2009
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
Hi, my fujitsu fi-6130 hangs after a few scans. This happen once in a while where i have to kill all my application in order to work again. Any idea why this is happening?
Does the scanner have any error code displayed on its display? If so, what it it? What software are you using to run the scanner?
Sep 28, 2010 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
No picture with Yamaha 6130 reciever. have
The TV must be tuned to the correct input also. Please cycle through the tv inputs by pressing the input button on the tv one time, then wait 5 to 10 seconds for the tv to recognize the input signal. If nothing, press again. You don't say which tv you have but many newer models have 5 to 7 input sources you will have to cycle through to find your signal.
With out more information, this is just one step in finding out what could be wrong. Please rank me accordingly.
Good luck.
Feb 28, 2010 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
Getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Jan 31, 2009 | Icom IC-R5 Handheld Scanner
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Fujitsu fi-6130 Flatbed Scanner Logo
164 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
