Question about LG LRE30451 Electric Kitchen Range
LG Range Touchpad Not Working
My stove is only 2 years old and I can't cook in the oven unless its 350 degrees. The touchpad does not work at all. I have also been having problems with the right front burner. Sometimes the touchpad works, other times it doesn't. I can get it on low but any other setting is hit or miss. I suppose eventually it won't work at all. Very unhappy with LG appliances. Would never buy anything else LG!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 161 Answers
The touch mebrane is faulty and needs to be replaced.
Posted on Jan 22, 2010
My maytag flashes the code F1. What does that mean?
I just went through the same thing. According to what I have researched, it means a problem with the touchpad. Found out the clock/touchpad can run up to $200 to replace minus labor. I had nothing to lose so I took the back panel off the stove, took out the unit which is held with 4 screws, and used alcohol on a qtip to clean the circuit board. Mind you the stove is 15 years old and wasn't about to pay 200 dollars for a part. Put it all back together and the error code went away and the oven is now working again. It is getting me through Thanksgiving but I am buying a new stove because I don't know how long this repair will last. You have to consider the age of your range and what you are willing to pay.
Oct 18, 2014 | Maytag Ovens
Stove is connected It shows F1 what does this
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (1.e., not cooking) mode or,
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Hope helps (remember to rate this answer).
Jun 12, 2011 | Maytag MGS5870 Gas Kitchen Range
F1 came on when i was cooking with my oven and stove top on
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Kenmore 94312 / 94314 Electric Kitchen...
LG RANGE LRE30451SB GETS ERROR CODE F1 AFTER OVEN CLEANING AND WILL NOT FUNCTION
Feb 18, 2010 | LG LRE30451 Electric Kitchen Range
Display panel on stove not working properly, cannot use the oven
&^%$tr
Jan 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Hi, My LG Dual Convection oven is taking over one
mine too. it took 2 hrs to get to 300. Self cleaning does not get hot enough to clean. it seemed to work for a day after that, but is not working again. i got the error F-7 but can't locate my book to see what that means. the stove is only 1 year old....have you found an answer to your problem??
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
F1 Appears on Kenmore Electric Range
Sep 23, 2009 | Kenmore 90154 / 90152 Electric Kitchen...
We have an LG over the range microwave and boiling a pot of water on the stove apparently shorted out the key pad. The numbers don't work and the vent and light buttons work intermittently. Note that this...
We have an LG LMVM2075SB over the stove microwave that we purchased in December, 2007. A few weeks ago, several of the positions on the touchpad stopped working.
I assumed that the problem involved the touchpad itself. I ordered a new one (Part number MFM37134802 - $25.30 plus shipping), and we installed it today. This solved the problem.
J. Adams,Alabama
The installation was not simple. The door has to be removed and disassembled to enable you to get to the connector that connects the touchpad with a circuit board. We heated the old touchpad with a hair dryer and pulled it off (after disconnecting the connector). The new touchpad comes with an adhesive backing. You have to be very careful in placing it because the adhesive is very strong. The touchpad fits in an identation, so the placement of the new one must be perfect.
Failure of the touchpads on these LG models seems to be a common problem. It sounds like a design problem.
Jul 07, 2009 | LG Microwave Ovens
Touchpad doesn't work, F1 code
Most likley you have a bad touchpad. Most times its a key that is stuck and there is nothing much you can do except replace the touchpad control. It is a common problem with all electronic ranges. If the range is 13 years old I would thik about replaceing it. Good luck
Jul 15, 2007 | GE JBP90 Electric Kitchen Range
LG LRE30451 Electric Kitchen Range Logo
1,066 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
