The part that holds down to go to the rinse cycle wont work fills but wont drain
    Problem Solver:
  • 14 Answers
Could be clogged pump
Posted on Sep 03, 2009
Gets stock in rinse cycle
Rinse cycles are usually with cold water. If it cant fill with cold water, it wont go through the rinse cycle. Make sure it fills with cold on a normal wash. You may find its filling with hot only. Alternatively, the machine may not be pumping out properly, this will cause a similar fault. Check to see the machine is draining at the end of the wash. check the pump and the filters for blockages or lint etc clogging the hoses or pump.
Feb 18, 2015 | Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
