Question about Maytag SAV365ZAWW 22 CYC 4SP 3.3 CF BRAND IN STOCK
Maytag model SAV365ZAWW, Serial No. 10075532EC; I replaced the belt on my waher but it's rubbing on the pump and is slightly shaving the belt. Need diagram/picture for proper placement of belt. HELP! Single Mom had tons of laundry to do. Thank you.
  • 612 Answers
You have now found the problem that caused your old belt to fail. you will need to replace your idler lever assembly. go to www.partselect.com and enter your model number. This is your part number you will need. PS2027756 The site will give you a parts blowup so that you can see the part you need. You can also order the part from them. The Idler lever is worn and causing your belt to be misaligned.
Please rate solution
Posted on Sep 03, 2009
  • 220 Answers
Http://appliancejunk.com/forums/index.php?PHPSESSID=6805e6d41e8f062f912a900b13b2b84a&topic=97.0
Sav365zaww skips the drain and spin cycle - sometimes
it could be that you have somthing stuck in the pump or outlet hose I went to a machine the other day and it had a intermitent fault like yours and it was a coin stuck in the drain hose on the pump when it washed in cold it was ok but when it was a hot wash it expanded the hose enough to allow the coin to flap up into the pump outlet hole hope this might help you
Dec 01, 2011 | Maytag SAV365ZAWW 3.3 cu.ft.
My neptune washer is makintg a bearing or a rubbing noise, I took the back off and the pulley is rubbing the inspection cover
THERE IS A RETROFIT KIT FOR THIS PROBLEM..YOU CAN FIND IT THRU REPAIR CLINIC.COM..USE YOUR MODLE NUMBER..THE KIT CONSIST OF A LARGER WAHER AND REPLACEMENT LOCKING BOLT..GET A NEW BELT WHILE YOUR THERE,A PIN TO PUT ON BUT YOU'LL THANK ME LATER..RDS
Apr 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
It started smoking and now the drum will not turn
the belt may have got stuck and burn into...thanks
Jan 04, 2010 | Maytag SAV365ZAWW 3.3 cu.ft.
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG EPIC FRONTLOAD WASHER NOT DRAINING
The filter is in the front on this one. Under the door, there is another panel. There are 3 screws that a 1/4" nut driver takes off pretty easily. Get a bowl and bucket. There is a white screw cap that you should easily see. Open it slowly with the bowl underneath. Close it again when the bowl is filled and dump the bowl into the bucket. Repeat until no more water comes out then unscrew it completely. Clean out the trap and replace. There is a stop that prevents you from overtightening. See if that works. A six dollar nutdriver is easier and cheaper than any repairman.
Jun 16, 2009 | Maytag EPIC MFW9600S
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
May 31, 2009 | Maytag Washing Machines
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Waher maytag
Pull your washer forward then tilt the top backwards until it sits at about a 45 degree angle. There should be a belt and 3 pulleys underneath. Remove the belt (one of the pulleys will move to allow slack) Ignore the moving pulley and the large pulley in the center. The third pulley is your pump. Try to turn it by hand, it should move freely. Presumably, it wont and will need to be replaced.
May 26, 2008 | Amana NAV5800A Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
