Question about Lisle 51250 Spark Plug Wirepuller
I need to no which spark plug wire goes onto which spark plug
    Sergeant:
  • 384 Answers
No or know?
How many Cylinder do you have?
If one it pretty straight forward. If eight, you have one chance in a million you will get it right.
Posted on Sep 04, 2009
Replace the rcx59006 connector socket on my rcx50070 floating cord assy.
Get a new spark plug wire, you probably destroyed the graphite inside the existing cord pull and pushing, crimping the parts onto the old wires.
Everything to know about Spark Plug wires:
Getting Wired Spark Plug Wires 101
Some guidelines:
Spark Plug Wire comparison Read this before purchasing WIRES Dodge SRT...
Mar 03, 2015 | Hayward Industrial Products Hayward Tiger...
Why do my spark plug wires I'm my 1994 ford
Probably not seated well on the plug. When you push the plug wire boot over the plug, you have to make sure the wire end terminal's ring end snaps onto the spark plug. It is not connected tight until you hear the wire's end terminal snap or click onto the tip of the spark plug. If you can't hear the snap, the end of the wire may not be seating onto the spark plug tip. Push the boot back away from the spark plug wire end to investigate-the boots can get very stubborn with age-keep twisting it and pushing it till you get it moving back from end of wire. Examine the metal end tip of wire-trey to snap a spark plug down onto it now-if there is a problem with the end terminals you will see it-it may be too big to snap over the spark plug tip and hold securely, or if the ends are bent, use pliers to straighten them out. If these are aftermarket spark plug wires, the end terminals may be too small to go over the spark plug tip. You would then need a new set of spark plug wires.
I suspect you just have not pushed the wires down far enough to seat them on the plugs-push the wires onto the plugs until you hear them snap or click. Then they are seated firmly, and should not be popping off.
Sep 04, 2013 | Cars & Trucks
I have spark at the cap but not to the sparks, already change rotr
Ok, heres how the spark works, coil, to cap,, along the rotor to the connection pins of the cap, to the spark plug wires,, and onto the plugs, inside the cap, make sure that the little center piece is hitting the center or the rotor, which goes out to the tip of the rotor,, that sends spark to the pins inside the cap,, now if your cap has any corrosion or tiny cracks,, that spark will go all over the place and not travel down its intended path, so clean off those contact pins in the cap, or replace it, if you have no spark to any of the plugs,, change the cap,, if its just to one or 2 , check the plug wires and the plugs themselves
Sep 28, 2011 | 1990 Ford Mustang
Where are the spark plugs located at
I found this solution and will not take credit for it, I had the same problem. To change the spark plugs on a 2000 Kia Sephia, at least in a 1.8L version, first disconnect the battery, then, remove the black plastic cover on top of the motor. There should be 6 Phillips-head screws holding it down. After removing the plastic cover, you will see two rubber covers for the spark plug wires on each side, and two gel-looking insuated tubs attatched to more wires in the middle. To remove two of the spark plugs, you must carefully pull the rubber covers upward. They clip onto the spark plugs so you will need to use careful force to pull them out. Once you have them pulled out, you can look in and see the plug. It requires a 5/8 spark plug socket with an adapter to reach in. Make sure you push the socket on hard enough so that it clips onto the spark plug, other wise it will fall over and you wont be able to get it out without a LOT more work. Finish that plug by plugging the rubber covered spark plug wire back onto the spark plug, covering the hole. You can do the same thing for the plug on the opposite side. For the two in the middle, you need to first unbolt and remove the insulated boxes that cover the spark plug holes (you can unplug the white connectors but make sure you plug them back in when you are done). Then all you have to do is do the same thing you did with the two outer ones to replace the plugs. Perform this one plug at a time, and make sure you cover the holes with a cloth or paper towel if you leave them open for any period of time. When you finish, make sure all the wires are connected, then reconnect the battery.
Sep 15, 2010 | 1999 Kia Sephia
91 jeep yj wont start
check your coil, plugs, wires, basically your entire ignition system - test a plug wire by sticking a new (known to spark) sparkplug onto the end of the (known to work) wire and see if there is spark, if not, change out your coil and test again - if neither, check the timing of your distributor
Jan 28, 2010 | 1991 Jeep Wrangler
Car sputters and no power, now it will not crank
Check the coil pack. they are common to fail and the engine will usually misfire for a while and then not start when it gets cold out. you can do a quick check by removing one plug wire at a time and having someone crank the engine. the spark should jump right down the tower the wire goes onto to the base of the coilpack. if this does not happen then you need to replace the coilpack first. take the 6 tork head screws out and remove the wiring under it that goes to the module. carefull not to mix up the wires under the coilpack or to the spark plugs. reinstall the coilpack and reinstall the plug wires and try to start the engine. i will look for a response incase you need more help. good luck.
Dec 31, 2009 | 1991 Buick Park Avenue
Where is distributor located1995 960 6cyl
hi, if you follow the leads that come from the top of the spark plugs where all these leads plug into is the distributer their will be four leads running along the outside going to each spark plug then the lead that goes into the center of the distributer goes to the coil.
So if you follow the four ht leads from the spark plugs what these all plug into is the distributer, if you are removing the distributer then make sure you mark where each lead goes as you need to put them all back in the right place.
Its best if you mark say the first lead with a 1 and then write a one onto the distributer where that lead goes into use permanent marker pen to do this so it dont rub off. getting the leads the wrong way round will mean the car will either miss fire or not run at all so just keep it all marked up properly.
Let me know how you get on or if you need further assistance ok
Nov 06, 2009 | 1995 Volvo 960
Car wont start, sounds like out of gas but tank is full
A car not starting can be caused by many, many things.........but...................a bad thermostat or a good thermostat will not cause or keep a car from starting in any way. you need to know if it is getting gas to the cylinders........and to check for spark at the cylinders.......pull a spark plug wire at the spark plug, pull the spark plug and see if it looks wet or smells like strong gas odor....then plug wire onto spark plug, (without re-installing spark plug), and hold spark plug onto a grounded metal object on engine (using a rubber insulated object, so you don't get shocked), then have someone turn engine over and look to see if spark plug sparks........if yes, re-install spark plug, etc.......your ignintion is sparking, but if you are getting fuel, it may be a jumped timing chain? You may need mechanical help........don't trust the person that told you about a thermostat........
jtarin@cox.net
Jul 16, 2009 | 1997 Chevrolet Malibu
1994 Suzuki Sidekick spark plug cover blown out.
Oh, ok. No, they shouldn't be related. The plug cover meaning the spark plug wire boot that goes over the spark plug hole? Why won't it stay in? Is the spark plug missing? Those plug wires snap onto the spaek plug holding the wire on the plug.. There should be a spark plug in the hole. If not, you probably had it blown out. That happens once in a blue moon. If the plug is missing, get a new one and carefully install it by hand, no rachet. If the plug won't start in the hole the first few threads mat be strippe. Do not cross-thread the new plug. Spark plug hole taps are available at parts stores. good luck
May 22, 2009 | 1994 Suzuki Sidekick
Spark plugs
Open the hood, look for the distributor, it will have 5 wires coming out of it, they will be about as thick as a pen, and most likely black. One wire goes to the coil, follow the other 4, they plug onto the 4 spark plugs. Let me know how you do. countrycurt0
Sep 10, 2008 | 1998 Dodge Caravan
Lisle 51250 Spark Plug Wirepuller Logo
Top Lisle Measuring Tools & Sensors Experts
Jerry Kramer
Jerry Kramer
Prariehog
Prariehog
Mai Lor
Are you a Lisle Measuring Tool and Sensor Expert? Answer questions, earn points and help others
