I have a 17mf200v/17 magnavox flat screen/monitor tv that has good sound and no picture can tou help.
  • 1 more comment
  • cjackson14 Sep 04, 2009
    hi, i check all you solutions and all were was no help. all i did was tune it on with the remotes the pic came on and went out.any more ideas. thank you
  • cjackson14 Sep 06, 2009
    good morning .will i still have sound, thank you
  • cjackson14 Oct 02, 2009
    just to let you know,the LCD panel was bad.replace it and worked fine them. thank you for you help.
  • 3,741 Answers
Its High Voltage problem. Check fly back transformer in the unit.it has to be replaced. in the flyback circut it is common for the solder connections to get heated up and become disconnected, so try resoldering any bad solder, if that don't work the components will need to be tested and the flyback high voltage transformer will need to be tested for connectivity(after voltage discharge) if this don't work then the tube or the crt board is failing.but if the flyback is proper then
It is the capacitor. Magnavox installed a power system that is insufficient. All you need to fix the problem is a 2200 watt capacitor that is heat resistant up to 150 degrees. You can get one at www.radioshack.com for 4 bucks.this will help.
thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 06, 2009
    Brigadier General:
  • 4,090 Answers
Well some more information would have been an advantage.
When did it occur was it Ok before Wasthere lightning recently ( in the time it was last on and now)
1) Make sure brightness is turned up.
2) Ensure you are actually on a fully tuned channel
3) it hasnt accidently been switched to monitor mode
Those are common occurrences, because someone fiddles with it.
Have to get the obvious out of the way first.
Loss of picture can be many things on the component board, from a bad IC to a capacitor birning out. Whatever, it is related to componentry if not the simple things.
If you are not skilled in electronics to be able to investigate it yourself with the use of a mutimeter to check voltage etc It would be wiser to take it to a repair outlet.
If there is any warranty then use that to have it repaired.
If there was a storm and you can show that there is fusion then a claim on your insurance will at least pay part of the bill.
Posted on Sep 03, 2009
  • dennis bullard Sep 04, 2009
    If when you turn it on you get a brief picture and then nothing the power board is damged. The sensor for power overload cuts in and blanks the screen to try and cut down on the amoint of power and heat. This is a safety factor to prevent combustion ( fire) from overhating of circuit.
    Call a technician to have it fixed and refrain from trying to make it run, unless you have insurance and want to get a new house
I have a magnavox 32mf605w/17 flat screen TV my sound us not working is there any way to hook up external speakers to it?
Hi Lisa,
Many a times the speakers in flat panel TVs go bad. You either change the speakers or hook your tv to some sound system like a home theater or some music system in your house. There is AV out sockets at the back of the TV. Out of the three ie. yellow, red and white use red and white to connect to the music system, put the system on auxiliary mode and enjoy the sound of your tv. Good luck.
Apr 08, 2015 | Magnavox Televison & Video
CANT UNLOCK MY TV
Try factory default 0000 or 1234. Or if its a three digit code 000 or 123.
Hope this helps
Apr 01, 2011 | Magnavox 17MF200V 17 in TV
I have a Magnavox 30mf200v/17. When I turn it on the sound works but there is no picture.
Turn the tv on now,have pictures only flashes a few sec. than pictures dies,than have sound left only?Yes,than tv have those 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 30, 2010 | Philips Televison & Video
My Magnavox 17in LCD TV (17MF200V/17) shows message ''Attention OSD Main Menu locked. cannot use any functions on tv. i.e., volume , menu, etc
It means that some kind of parental control feature has locked you out of the On Screen Display menu. You will have to consult your manual (possibly online) to figure out how to reset the password.
Although it is possible some other kind of malfunction could cause you to lose menu control, this is the most likely cause.
Oct 07, 2009 | Televison & Video
Tv with sound but no picture
ur video inverter board is ded.
Need new one.if u lucky it just lose.
Aug 14, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Screen goes out but sound remains
A blown fuse would not be intermittant.
It is possible that the back plane lamps, and or the back plane power supply is failing.
When the set is in the dark screen, shine a flashlight on the screen at an offset angle. Look carefully and see if you see the picture images. If so, this proves that the back plane lighting is having a fault condition. If there is no image at all, then there may be a fault condition with one of the drive boards for the picture processing or the screen itself.
Jerry G.
May 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
MAGNAVOX 17MF200V
Could your remote possibly need new batteries? Sometimes remotes act erratic when in need of them. Check that out and see if that is the reason for your problem. Luck!
~ KT
Jan 10, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
