Question about ASUS SiS Chipset P4S533 (P4S533 PA W/LAN) Motherboard
Slow start up on bios
My computer will take a long time to start up in windows Xp pro and bios but once it runs in windows I have no problem. what could be the problem?
  • ellswt Jan 13, 2008
    i too have an asrock mobo same problem,,
    amd athlon x2 4200 +
    nvidia 5200 fx agp video\
    1 gig of crucial pc 2700 memory
    asrock 939 dual vsta
    430 watt sparkle PS
    i have flashed my bios without results
W3400 runs very slow, 64 bit, 2gig ram xp-pro
Your hard drive has the defective, there are bad sectors already in you drive, that's why it run slowly even though you formatted it.
Mar 27, 2012 | E-Machines W3400 PC Desktop
7.0 Pro now slower than before
Adjust your OS to Windows 10.
Jan 25, 2018 | Adobe Acrobat 7.0 for PC
Windows XP start in safe mode with F8 not possible. What is wrong?
you are to slow, you must hack constantly in beginning on F8 to get in in safe mode. also try to get in BIOS with DEL button or F10, F2 depends what kind of computer your have. if that doesn't work, it seems like keyboards not supporting bios.
Oct 07, 2010 | Microsoft USB Slim Multimedia Pro Keyboard...
Slow running machine
It might be caused by spyware running in the background. Download, install and scan your hard drive with this. Spybot
http://www.safer-networking.org/en/download/
If it doesn't find anything then go to Start, Programs, and Startup. See if there is anything that you don't need to start up every time. If you find something there that you don't need then delete it from that folder and it won't start.
The next suggestion should only be done if you are comfortable with using Regedit.
Go to Start, Run and type Regedit
Go to HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
and check in there for programs that are not needed to start everyday. Please don't delete any keys that you are unsure about.
Apr 20, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Windows xp pro blue screen
could look into the bios by pressing f12 or f2 or whatever for your model. Once inside the bios you can have the machine boot via hard drive at also check the hardware functions.
Jan 28, 2010 | Panasonic Computers & Internet
XP Pro only starts in Safe Mode
this is basically problem related to your hardware.. please check that you meet all the hardware requirements as well as you must have proper copy of that Xp to be installed. And if that so, then you must go BIOS settings by Pressing F8 key at booting time where you must change your booting sequence...Your problem will be solved.
if it doesn't work,then check all the drivers to be needed after installing the XP.
If the problem still persists, then you must reinstall XP.
Jun 11, 2009 | Microsoft Windows XP Home Edition
Slow computer
Pro won't make it run faster. Make sure the processor is fast enough to handle XP. If it's an older computer you've upgraded to XP, it may not have the horsepower.
Read this page from Microsoft:
http://support.microsoft.com/kb/314865
If the CPU conforms, the best thing to do is add RAM. I recommend a minimum of 1 GB for XP machines.
Make sure the hard drive is not nearly full, as that will limit the paging file that Windows uses. If your drive is near capacity (+90% full) it will slow down any computer, regardless of how much memory you have, or what speed the CPU is.
Jul 17, 2008 | Computers & Internet
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
Clean XP Pro installed -- now NIC disappeared!
Well once you did a clean install over all of Dell drivers etc etc. You wiped out the restore artion that was on the computer. You have to go to Dells website and under the support tab look for the Nic card that you have inside the computer.
Feb 08, 2008 | Dell Latitude C610 Notebook
ASUS SiS Chipset P4S533 (P4S533 PA W/LAN) Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
