Question about McCulloch Garden
Plastic fuel line broken - McCulloch Garden
  • dontbother10
    dontbother10 May 11, 2010
    Make and model would be helpfull. Also where it's broken might be beneficial. We're pretty good but can not see images within your head. Lou
  • 285 Answers
Basic solution is to replace it. You can buy fuel line from any good outdoor power tool store or specialist. Just remove and take your broken fuel line to match up a replacement for size and diameter, cut to length and fit it to replace the broken one. If you are not confident with doing that or not sure how, have the specialist repairer do it for you.
Good Luck!
Posted on Sep 04, 2009
How do you remove the fuel line from the intake manifold on a Ford Ranger XLT with a 2.9 Litre engine?
Not sure what you are saying that broke.
If the line is plastic and the fitting has no place for a wrench, you use a tool made to release the spring tension inside the connector. AC lines use the same setup.
If the plastic line is broke, you may be able to get a repair kit at your local auto parts store. The fuel line is designed to be replaced all in one piece, not repaired.
Nov 25, 2015 | Ford Cars & Trucks
Fuel line in tank has come loose, where does it connect inside tank
Some just connect externally to a barb fitting, but usually the fuel line and filter are all one piece. They are a bear to remove and replace because most of the new saws have a built in grommet in the fuel line itself to seal the plastic tank hole as it passes through it. Yours may have broken off inside the tank at the grommet. If so, its time for a new line/filter.
Apr 17, 2015 | John Deere J3816 Chaninsaw Switch
1950 poulan
Open fuel tank, pour out fuel on clean flat area (away from any flames or spark sources) then check the 2 plastic hoses inside. One should have a fuel filter on it's end. The plastic these lines are made seams to disintegrate so, filter may not be attached and lines may be broken off. Replace them.
Mar 05, 2013 | Poulan 14" Chainsaw
I need to replace a broken fuel pressure regulator line on my 2004 chevy impala. I need to know where the line leads underneath the vehicle
The black plastic line goes to the map sensor - there should be a tee fitting to connect it there. It does not go under the engine or the car.
The steel fuel lines do go under and back to the gas tank.
Dec 22, 2012 | Cars & Trucks
I have two broken lines to my gas tank.How do I fix?
No idea
Check with a dealer
After that---you have to have the repair kit
for plastic lines,if that is what they are
Why would even one line be broken?
Oct 04, 2012 | Jaguar XJ8L Cars & Trucks
What do I do if the clamp on the fuel filter is stuck?
There is not much to it, remove the retainer and pull the line off, now if you broke part of the clip then push the fuel line closer to the filter and get a pair of needle nose pliers and remove the broken plastic
Apr 05, 2011 | 1999 Ford Explorer
Plastic line to filter disintegrated from heat....
Hi, dont know too much about craftsman, I think it's part of Sears so your strimmer will be badge enginered, if it has two fuel lines my guess is it's japanese, fuel line is available at your dealer or local home base store, if the fuel lines just enter the tank through holes try to get rubber pipe, it seals better, although a clear pipe would be better for the return pipe, thats the one that just pokes into the tank, it's perpose is to return fuel to the tank after priming the carb, to ascertain which is which place your finger over each nipple on the carb in turn as you press the primer button, one will **** on your finger and connects to the filter the other blows and is the return, the return pipe only has to just enter the tank, thats all. hope this helps. a new tank will cost a small fortune if it's japanese. hope this helps. regards Tony (England UK)
Aug 31, 2009 | Craftsman 25cc Gas Line Trimmer
How do you replace the gas lines?
ok the first thing you do is get the right size fuel line get the fuel line extra long run the line through the hole in the tank from top long needle nose pliers to pull through the tank on the inside install fuel filter on the line that has it then pull it back up measure to the carb then cut at right lenth if i can further help e-mail me @ wadembly@aol.com thanks, wade
Jun 08, 2009 | Garden
Plastic piece...what is it?
Go to a ford dealer parts dept and show them the piece and where it goes, thy will be able to ID it from the parts illustration books easily.
Nov 04, 2008 | 1990 Ford F350
Garden Logo
55 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
