Question about Abit AN7 Motherboard
Locks during xp install, wont go past "inspecting hardware cnfg"
Boots from cd ok.... gets to setup is ispecting hardware configuration screen
    Sergeant:
    Champion:
  • 208 Answers
Try resetting your Bios to factor default and see if you get further.
Posted on Sep 03, 2009
My window xp is corrept what to do
Don't worry it is very easy to fix it.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
When presented with the screen below. press the F8 key to continue.
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
Jun 24, 2010 | Computers & Internet
Tip
How to repair windows xp operating system
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different.
Note: If you need assistance with a repair installation, please start a new topic in our Windows XP Forum. This topic is also open for comments, but not all will receive a reply.
IMPORTANT NOTE: After running a repair, you may find that Windows Update refuses to install the most recent 80 patches. This is because the latest version of Windows Update is broken, and doesn't register some DLLs if they're previously been registered (as happens with a repair install). Here's a work around until they get it fixed:
Stop the Automatic Updates service. To do this, follow these steps:
Click Start, click Run, type cmd, and then click OK.
At the command prompt, type the following commands, and then press ENTER after each command:
net stop wuauserv
exit
Register the file that is used by Windows Update and Microsoft Update. To do this, follow these steps:
At the command prompt, type the following command, press ENTER after the command, and then click OK when you receive a verification message:
regsvr32 %windir%\system32\wups2.dll
Note: for x64 machines regsvr32 %windir%\syswow64\wups2.dll
Start the Automatic Updates service. To do this, follow these steps:
net start wuauserv
exit
on Jul 02, 2010 | Computers & Internet
Tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
Let's get started!
Let's get started!
on Jun 18, 2010 | Computers & Internet
HOW TO ENTER CMOS SETUP OR BIOS SETUP OF SONY VGN-FW290E OR HOW TO INSTALL WIN XP IN THIS NOTEBOOK
To enter the CMOS setup BIOS you hit f2 during the power on. After you enter the bios to the boot up screen and select first boot up = CD ROM. Save the configuration and reboot. Now pop in your windows XP cd into the CDROM, your computer will bootup from the CDROM. You can now reinstall windows.
Dec 11, 2009 | Sony VAIO VGN-FW290JTB Notebook PC
Turn power on it starts to boot up fan turns on it gets past the f2 setup then goes to a windows xp blue screen and stays ther.
Hello there:
when you boot the computer hit the f8 key repetedly and the xp startup menu will appear than select last good known configuration that worked and press enter and see if it will now boot. ok also make sure there is not any disks in the computer ok. please let me know how this is going there may be more i can do if needed also dont forget to rate the solutions i have provided
best regards
michael
(USN) RETIRED
Aug 06, 2009 | Computers & Internet
Ntldr is missing in pc and when i tried to boot xp cd it checks for hardware configuration and black screen appears
you just need to replace it, just use the boot disk for your os to boot the system up then copy paste ntldr into the root of c, if you have probs repost
Jun 02, 2009 | Western Digital 320GB MyBook External USB...
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
How to install win xp in toshiba portage r200 laptop
This is resolved by installing Intel Storage Manager drivers through "F6" option on XP Setup. YOU MUST HAVE AN EXTERNAL FLOPPY DISK (A Drive)...as the Portege doesn't come with one...and XP does not support USB or CD ROM for this particular function.
Mar 18, 2009 | Toshiba Portege R200 Notebook
I have 2 drives C:\ and D:\ Im trying to reinstall my windows but my c drive would not allow me to do so. Instead I could only do so on D:\ Now I have three options during bootup: c:\Windows, D:\Windows...
Hi.
Insert the xp CD in the drive.
Where it asks you to choose a location to install xp, just delete both the partition. (default button D)
Then make two fresh partition and install xp in the first one (that is C).
This will solve your problem.
Regards
Faraz
Oct 14, 2008 | Computers & Internet
Installing win xp in hp pavilion dv2000
OK...
F10 to enter setup,
system configuration,
and disable SATA native
Aug 02, 2008 | Computers & Internet
Abit AN7 Motherboard Logo
47 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
