Question about Roomba Vacuums
My Roomba Discovery will not do our carpet. It is a medium pile tan carpet so it should be OK but it runs for a little while then shuts down and beeps. It does not try to restart.It works well on floors. I have recently done a full tear down and cleaned the drives and brush transmission.
SOURCE: Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Posted on Nov 25, 2007
  • 20 Answers
SOURCE: Roomba Discovery
grrrrr
Posted on May 10, 2008
  • 5 Answers
SOURCE: Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
Posted on Jun 18, 2008
  • 17 Answers
SOURCE: Roomba Discovery 4120 barely moving
I don't have the same roomba that you have, but I had a lot of dog/cat hair stuck on the fan in the trash bin section. Once I removed that it started to work again. I used an air compressor to give it a really good blow out.
Here is a link that might help you out.
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=10960
Phil
Posted on Jan 10, 2009
SOURCE: roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Posted on Feb 24, 2009
My purple Dyson Animal (without the ball) isn't working correctly. When I turn it on, the red power light, as well as the medium pile buttons flashes. When I first turn it on, the brush rotates for 3 to...
I need help repairing my Dyson. I cannot push the buttons down to select Short pile/Medium pile or bare floor. The buttons will not push down at all. It will not allow me to select anything. I have very short pile carpet so it does not pick up that well.
Oct 23, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Roomba Discovery SE Bagless Robotic Vacuum: My Roomba battery charger has no lights and does n...
use a multimeter to test if it is actually putting out a charge. Is this a regular roomba charger with the green led on top? And it just doesnt light up anymore? If so then the pack is dead. replace it.
May 16, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
My roomba discover started running realy slow or barely moving when on carpet
Replace your belt also check the end-caps on your beater bar to see of they are packed with fibers. clean out any you find.
Feb 19, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
Turns in circles, acts like it hits a virtual wall then stops
Reboot is probably not your solution. Your Roomba will react to invisible signals or 'interference' from other electrical appliances as well as the invisible wall boxes. You can clearly see how this happens when a Roomba gets near your computer or other device that is on. Also, the Roomba will go in circles when the dirt chamber is full or it thinks it's full. Try a thorough clean of all major parts including the brushes. Sometimes this activity will occur when the brushes get snarled on thread or carpet fibers.
Oct 09, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
My roomba 400 series keeps stopping on its own
Take off the grill on the back of the bin. The round vacuum impeller is behind it. Make sure that's clean and free of debris. Run the Roomba with that little grill still off the bin-- is the impeller turning? If yes, you may have fixed it. If not, your Roomba needs a new vacuum bin.
Aug 26, 2009 | Roomba Robotic Floor Bagless Vacuum
I bought Roomba 560 robot vacuum cleaner about 3 weeks ago and it has been cleaned without problem all kind of positions of floors (also carpets) Last friday I anyway mountained nearby of outcoming door...
Roomba won't clean black carpet because it interprets it as a cliff. The sensors under the bumper tell the Roomba that it's about to fall down the stairs and it backs away. Unfortunately, because they're a safety feature, they can't be shut off.
Aug 18, 2009 | iRobot Roomba 560 Robotic Vacuum
My roomba discovery will not operate on the clean or max buttons, will do the spot clean and goes forward then circles. Turns itself off and plays a little da do da do do do do. I have emptied tray,...
If your Roomba goes "uh-oh", beep-beep-beep, that's a 3-beep error code, indicating that your vacuum motor is stalled. Remove the grill from the outside (back) of the dustbin and make sure that the impeller (looks like a fan) turns easily and is not clogged with dirt. Then try to run the robot with the bin ON but the grill OFF. You should be able to tell whether the vacuum impeller is spinning. If not, you'll need a new bin. You can confirm wth customer support by calling 1-877-855-8593.
Jul 16, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
After charging overnight, Roomba only runs about 25 minutes before shutting down with a red light.At this point the battery measures 15.13 volts ( about 1.26 volts per cell ) My hobby experience is that a...
Reset the Roomba by removing it from the charger, then holding "spot" and "dock" for about twelve seconds. When you let go, the unit will play an ascending series of notes. Then recharge it overnight. If the run time is still short, give Customer Support a call-- be sure to have the Roomba with you when you do.
Jun 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Keeps stopping.
your battery isn't holding a charge ,buy a new battery
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Vacuums Logo
132 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
