Question about Activision Guitar Hero World Tour Guitar Bundle - Wii Game, Wireless Guitar for Nintendo Wii
Broken yellow pad
My little cousin pulled the wire out of the jack connecting the wire to the pa and i don't know if the warranty will cover it or how to get it fixed !!!
I have a similar problem with the yellow symbol, if i have to buy a new one, where do i go to purchase it?
Posted on Sep 10, 2009
  • 3 Answers
Just go but a new one that's the only choice!
Posted on Sep 05, 2009
Pa
per fcc rules (laws)? you cannot put an amp on a cb. max output 4 amps. you should be able to put a pa speaker using the pa output jack. take your radio back for warranty.
May 19, 2013 | Cobra 19 DX IV CB Radio
I have service error 6800
Please follow the steps below to hard reset the printer and let me know the result.
1.Remove all the cables from the printer.
2.Wait for 10 mins.
3.Connect only the power cord and try to power on the printer.
4.If the problem is solved, then connect all other cables, otherwise let me know.
This is basically a hardware error related to Purge Unit/Waste ink absorber (WIA). If printer is in warranty get it replaced by Canon. If not please try to follow the steps below and check, if you can resolve the problem in home.
1. Open the printer cover and when the carriage head moves to center pull out the power cord.
2. The WIA unit is on the right side. Use a flashlight to check, then you will see two ink pads (sponge). This is where the print-head is homed/parked and is the top of the WIA unit.
3. There you will find wiper blades that move from the rear to the front. They wipe the bottom of the print-head when it is homed.
(The ink pads actually drop down about three quarters inch, to allow the wiper blade to pass and then it is supposed to spring back to the rear. Also the ink suction for cleaning the print-head is done by the WIA unit.)
4. Use some rubber gloves and a paper towel and see if you can press the ink pads down just a little bit - about quarter inch. See if for some reason the wiper blade is stuck extended. If so, see if you can get it unstuck. Please do this gently so that you don't break anything there.
This error indicates that the WIA unit is not giving the correct timing signal as it rotates inside 360 degrees. Therefore, something is either broken or jammed inside. If you had a paper jam and tried to forcefully pull it out, you could have pulled the internal gears out of alignment or sometimes due to timing problem the print head and the wiping blades can clash with each other.
So you will need to do some maneuvers to try to release the cartridge from its parking position. Again, don't try hard.
Aug 28, 2012 | Canon i455 InkJet Photo Printer
When i pull the trigger the gun will not activate the battery is fully charged
A wire has come off the connection between the battery & the trigger or connections the triger & the motor, maybe (Blue & Yellow)
Use a philips screwdriver to undo the screws. The plactic covers will come apart. Best to lift only one side. Be careful when doing this & take note of where the cogs fit into the covers when you lift it. If there is a speed change swich on the top of the drill make sure you know which direction it was swiched to. (1 or 2) This is only a machanical swich but it can be a ****** if you move it & don't put it back in the right place. On some models only the handle will come apart, if so, you are in luck.
When you have it apart have a look at the wireing & find the one that has come adrift. It will be where the wire connects to something. Solder it back on. Don't mix the wireing up. There will be a Red Wire going to the Positive side & a Black wire going to the Negative side.
It's not rocket science. Anyone can do it, with a little care.
Feb 27, 2012 | Tools & Hardware - Others
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
I need a color coded wiring diagram for a peavey PV115 speaker cabinet.
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
Aug 15, 2011 | Peavey PV 115 Speaker PA Passive
Right side of bose headphone is not working
I have fixed over 500 headphones. Its the plug that connects to audio devices.
Take a look at it http://images.appleinsider.com/ipodiphoneav-review-5.jpg
http://sound.westhost.com/p70-f2.gif
Look at the Standard stereo headphone. When you plug it and unplug it from your audio/music device,
the little 3 or 4 wires disconnect. The smaller the headphone, the more chance this will happen.
To revive your headphone, you have to cut it and re solder the wires to the plug.
follow this step because I don't know how to explain it to you and make you understand it.
http://www.instructables.com/id/Easy-Headphone-Repair-for-Broken-Wires/
Please rate if this helped you.
Apr 19, 2011 | Bose Audio Players & Recorders
Blue and yellow cables. Which one is +?
The consense is that the yellow is positive... However, if these come from a 1/4 inch jack, the color that connects to the TIP of the jack is the positive one..
Feb 26, 2011 | Peavey PR15 400w PA Speakers
I have a Cobra 29 WX NW BT and i can not receive any transmisions unless the other CB user is right beside me. If they move more then a car lenght away i can see the signal come in but no voice. Also my PA...
You have a bad microphone. There is most likely a broken wire in the microphone jack.
Without a microphone the radio will not go into receive mode, at all. Same thing happens when there is a disconnected wire in the mic cord. Because the radio you have, has Talkback in it, you can always hear a little audio coming through, but not a lot.
Try a new mic or one you know is good.
Jun 11, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
No audio out of the radio's speaker or external speaker jack, but has audio from the PA jack.
The problem could be a range of things. Generally these radios use the same amplifier for the PA and receiver output. If the radio is receiving (usually the needle on the meter moves) then it may be bad contacts on the relay. Before pulling it apart check that the squelch setting is set to low and the RF gain is high. Check that the external speaker jack is not damaged (internally). If all seems OK visually try to connect one wire from a speaker (8 ohms) to the chasis of the radio and then use the other wire to probe different wires that are connected to the external speaker jack and on board speaker to see if you get an output there.
Sep 07, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Problems with Magellan Maestro? 4040 GPS power connection
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
Activision Guitar Hero World Tour Guitar Bundle - Wii Game, Wireless Guitar for Nintendo Wii Logo
201 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
