Question about Kenmore Ovens
The bottom heating element will not heat on my kenmore. I took out the element and had it tested and it tested out fine. Where do I go from here.
  • 8 more comments
  • millionairel Sep 03, 2009
    The front panel is electric but i am not getting any fault codes. When i turn the oven on it sounds like it should be working but it doesn't get hot(bottom only). I would estimate the oven at 7 yrs old. Its a Kenmore model 665 with a Schott Ceran cook top.
    I already turned off the breaker when I took out the heating element to have it tested. The model # is 665 I would estimate 7-8yrs old with a Schott Ceran stove top. I am also not receiving any fault codes as the front panel is electric.
    thanks
  • millionairel Sep 04, 2009
    Model# 665.95002102
    Serial# RL9016553
    I cannot find inside the oven. There's only 3 things that i can see inside. The top and bottom heating elements and a rod sticking out of the top back left corner that I'm assuming is the thermometer. The thermal fuse sound like a logical solution. Is there anyway I can find out where it is located on my particular model?
    Hopefully you are able to read the previous comments
    What about a thermal fuse that was previously suggested? the part # given was for a fridgidaire?
  • millionairel Sep 05, 2009
    Hey thanks for the tip, but it still didn't do the trick. I think I can officially rule out the heating element as my problem. FYI..I did check my breaker box and made sure they were both turned off and then back on. I'm not really sure what to do next? It really sounds like it should work(the oven). It's making all the right clicking sounds when I turn it on? Any more suggestions?
  • millionairel Sep 06, 2009
    Before I replace the thermostat I have a quick question. Would my broiler work if the thermostats bad? My broiler works fine and I can control the temperature on it accurately.
  • millionairel Sep 07, 2009
    I did not find any corrosion, as a matter of fact it looked brand new. If it is a thermal switch how and where can i check it? If you could submit pictures that would be great. Thank you for the thermostat comment too..I was pretty sure neither of them would work properly but obviously I'm not an expert.
  • 574 Answers
It very well could be the thermal fuse for the element. What I would do is pull the stove out where you can get to the wires to the bottom element and see if you have power to the element which you probably dont but check it anyways. I would then trace the wires from the element back to where ever they go checking everything may be a wire broke but you wont know until you pull thestove out and start checking.
Posted on Sep 07, 2009
    President:
  • 497 Answers
Sounds like just reading youre comments you've had some problem with it. To me it sounds like a thermal switch. When you took the bottom heating element out did you check for corrosion on the plug?
Posted on Sep 06, 2009
  • Greg Mills Sep 06, 2009
    and as to your comment about the thermostat, if it was a thermostat problem nothing would work on the bottom, either top or bottom heating element.
  • 3,037 Answers
That rod sticking out is the thermostat on the oven and it basically controls how hot the elements get and so if it is broken, then the elements won't heat. If you test it with an ohm meter it should have a low resistance, under 100 ohms generally, if it tests to over infinity or is over 1000 ohms, then it is bad and needs to be replaced. You can find a new one on www.repairclinic.com for cheaper than a store if time isn't an issue. These generally go out before the elements do. Let me know how this turns out.
Benjamin
Posted on Sep 05, 2009
    President:
  • 1,564 Answers
This is very common. Just ake a fingernail board and clean the pinch clips that it slides into, then do the same to the contacts at the core itself. Also, just for kicks, if this is a 220volt unit make sure that both breakers are in and not tripped.
  • Dana Newcombe
    Dana Newcombe Sep 06, 2009
    How did you make out?
    President:
  • 1,462 Answers
Hi.
You would need a volt meter to check for 240 volts across your bottom element terminals, where the electrical connections hook-up to it. If no 240 volts, then the problem is you electronic control board is bad as well.
Part# of electronic board 318010102
Else,try replacing the bottom element element for your model
ENJOY RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 04, 2009
  • 612 Answers
First, find your breaker. Turn it off and then back on. If this does not work I will need the model number to make a real diagnosis.
Posted on Sep 03, 2009
  • 1 more comment
  • James Hilton
    James Hilton Sep 03, 2009
    This is only the model. You will need to find the whole model number. You may have to lift it up. When you find it, there will be a serial number, model #, Volts, Amps It the data plate. There should be a series of letters and number in the model #. Also if it shows a series #. I may need it.
  • James Hilton
    James Hilton Sep 04, 2009
    OK, there is a thermal fuse (High Limit) inside the oven. This will have to be replaces before the element will energize. I'm thinking it's toward the rear. You can see it from inside the oven. It's round and has tow screws holding it and tow wires are attached. You can test it by connecting the two wires together and trying the oven element. If it comes on, the thermal fuse is bad. But do not use like this because this is by passing a safety
    Please rate this solution
  • James Hilton
    James Hilton Sep 07, 2009
    I responded prior to this with a part number for a High limit after you gave me this model number.
    Model# 665.95002102
    You responded with
    "What about a thermal fuse that was previously suggested? the part # given was for a Fridgidaire? "
    This is because Fridgidaire made this unit. I wanted to also tell you that if your thermal fuse test good, you will need to replace the oven sensor. It plugs into a wire coming from the control board.
    Sorry if I confused you before.
    Please rate solution
    President:
  • 1,714 Answers
Do you have the old style 'infinite' switch on the front panel or the new electronic control? If it's the old style, the infinite switch is bad and you will need to replace it. If it's the new electronic style, than that has a oven control module and heat sensors. I won't go into since you didn't mention any 'fault codes' or anything. It sounds like you just need a good old fashion 'infinite switch for the oven elemenet.
Neff 1541 not heating with replacement element
Yes two red flecked on same terminal and the black flecked on the other side terminal of the element. Bobs your Uncle......HEAT! Make sure they are a tight fit. New spades if required.
Oct 03, 2017 | Neff Ovens
I have a smooth top kenmore oven model #92172300 when you use the oven it gets to the temperature but then its shuts the heat off i had heating element tested and its good please help
The thermostat controls the heating element. If it comes to temp you know the element is OK. The thermostat can be tested. or just replace it.
Nov 18, 2016 | Kenmore Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Oven won't heat past 200 degrees
Unplug the range.
Remove the oven racks.
Remove the screws on the bake element.
Carefully pull the bake element out.
Remove the wires from the element.
Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
No reading is a bad element/
If you get a reading your oven control is bad.
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
27 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
