Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
48" Husqvarna Loss of drive
I'm experiencing a loss of drive on my 48" Husqvarna. I've replaced the drive motion belt twice this season and have only mowed once since changing it last. Initially, it was better but it quickly got to the point it didn't want to move very fast at all. I looked in the owners manual and it said the hydrostatic transmission is serviced at the factory and sealed and didn't mention anything about a hydraulic reservoir yet i read another post where someone had mentioned servicing hydraulics. Any help would be appreciated. It has 300 hours
  • 389 Answers
First of all, use only OEM belts48 from a dealer or in the case of Craftsman, from Sears or direct OEM replacement belts from a lawn mower2.gif repair dealer.
If you are using a generic "hardware store" belt, chances are you are getting a "fractional horsepower belt" which is made for low torque electric motors and they will not withstand the torture a lawnmower puts on them.
When installing the new belt, make sure all pulleys are clean and have no bent spots, burrs or cuts in them. Make sure that any idler pulleys spin freely and also make sure that you get them on the correct side of any belt guards.
The transaxle IS a sealed unit and is not servicable There are no parts available for it and no parts lists. Your only remedy is to take it to a dealer to have it replaced if it is indeed defective
You can go to this link, click on support and download a manual for your model number which gives belt routing, parts listings and a lot of good information pertaining to your tractor:
http://www.husqvarna.com/us/homeowner/home/
Posted on Sep 19, 2009
Why does my husqvarna running slow
Try changing the drive belt, even a slight slip on the belt will appear as a loss of power.
Aug 11, 2014 | Husqvarna Garden
Loss of suction
If it is not picking up from floor replace the belt. They need replaced at least twice per year because they lose elasticity and will slip when vacuuming floor. If it is loss of suction start by replacing filters. All filters should be replaced at least once per year on most vacuums
Oct 25, 2013 | Vacuums
The motion drive belt on my husqvarna yth2348 keeps coming off rear pulley above the transmission.
it sounds like an alignment issue check guide pulleys and make sure their not damaged or bent also check for broken parts
Sep 03, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2242 lawn tractor loss of drive.
You can check the belt tention, between the deck and the chassis just to see if it is loose, it would reqire removing the deck to replace the belt.
Apr 18, 2017 | Husqvarna Garden
I've got a 1997 chevy cavelier z24 and am
if it is a 2,4 dual over cam enginge it is the coil pack shorting out and it needs replaced
Jun 22, 2011 | 1997 Chevrolet Cavalier
Will not move forward or back
either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Mar 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Drive (motion) belt has come off the rear pulley twice in a month
husqvarna yth20k46
drive belt came off
fix
transmission boltes were not installed
replaced fix problem
Jul 16, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
I have the same problem.
It is either low on fluid or needs a fluid and filter change.
Aug 18, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna yth20S42 partial loss of drive power can tran oil be checked. The tractor has 170hrs operating time.How can you tell if its the belt or the trans. thanx Rod.
I would thing its the belt I have same mower u can check rear end by removing a check plug also sure that u can adjust the belt try that 1st
Apr 18, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
919 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
