Question about Roper RAX4233PQ Top Load Washer
My washer wont agitate or spin and is making a strange sound when it should..Please help
  • 415 Answers
Sounds like the motor drive coupler and its located between the motor and the gear case tip it backwards if you see rubber dust its broken just replace the it appx 20.00 it will take more time you can keep it tilted backwards you don have to remove the outter shell of the washer you'll need screwdriver a 1/4 or 5/16 socket a hammer/mallet and a piect of wood that fits between the pegs and tap on the motor shaft and the other fits on the gearcase
Posted on Sep 03, 2009
  • 220 Answers
Broken or worn out coupler...  http://www.davesrepair.com/DIYhelp/DIY285753.htm
  • 30 Answers
You need to change the motor coupling.
The part number is 285753A.
Remove the top panel and take the cabinet loose buy remove the two gold clips that holds it down to the back panel.
The coupling is between the motor and the gear case.
My Whirlpool Gold Ultimate Care washer doesnt agitate or spin. Makes a strange almost clicking like noise instead.
sounds like the drive block under the tub is stripped out or broken and it needs replacing,it sits under the tub to help drive the tub on direct drive models
Jul 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not agitate or spin. It fills with water but thats it. please help!
it sounds like your coupling is faulty. it goes between the motor and gearbox. if u need help to replace it please reply.
Apr 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
GE washer top load makes "chunking sound" in agitate cycle
unplug the machine- you should be able to turn the agitator by hand- turn it by hand- if you hear a noise, get a butter knife, or some other flat, thin item and move it around under the edge of the agitator, there may be a small object jammed under it! if so, then remove it, and enjoy the quiet! the agitators in many machines are removable- but you have to un-screw the top retainer, then use tool to loosen the agitator from the shaft- which can be a bit of a chore!! the older the machine, the more difficult! may want to check if your machine is level- but the spin cycle would tell you more! if it 'walks' across the room on spin, it's really out of level!!
good luck!
Oct 04, 2009 | GE WHSB8000B Top Load Washer
Weak agitation
hello mam
your machine will have this noise if the floor level is not good and if bearing is worn out so please call the tech and make him to check this.
Aug 30, 2009 | General Electric WHDSR316G Top Load Washer
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Washer will fill with water but won't agitate, drain or spin.
sounds strange... may be motor coupling... lean machine back and look underneath in between the motor and transmission... there is supposed to be a little rubber and plastic coupling there and alot of times it will get chewed up... the fact that it worked again after a couple days is a coincidence that there was just enough left to make it through the cycle... lemme know if that's not it
Apr 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
150 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
