Question about Hotpoint Dryers
My dryer is drying cltohes properly and the water collector is empty. What is the problem?
  • 415 Answers
David, no dryer unless a special one made for campers collect water please if possible discribe you problem or question what you think the water collector is to us techs/fixers then maybe it just something not identified properly
Posted on Sep 03, 2009
WONT DRY
Hi there, if your dryer is a condensing dryer then perhaps you need to empty the collector bottle , its is a compartment on the side of machine , open this and remove the bottle , this must be done after at least two sessions of drying. On the other hand if your dryer is of the vented type with a 4 inch flex vent it must be vented through the wall to the outside with no kinks in it , the reason for this is the water turns to vapour , and must exit the machine or you will have clothes that are still wet and water will collect at the bottom, its the same principal for the condenser machine only you have to empty the bottle of condensed water or the same result will occur.
Hope this is of some help to , Cassyjoe.
Nov 07, 2012 | Washing Machines
It says the water needs emptying but it is empty
After reading about various dryer problems / solutions it seems others have had this same problem. It could be that a smaller resevoir which houses the sensor connected to the water collector is full and it's valve may be blocked with lint. It can be solved by getting to the valve and removing the lint. You may need to remove the valve itself. Hope that helps. Good luck.
Oct 20, 2012 | Candy CDC266 Dryer
Wdl540 clothes go through drying cycle but come
If there is no heat at all then the heater or the temp sensor or the thermal fuses are defective and need replacing.
Also check that the lint filter is clear of debris and lint. Rinse it if necessary in some mild washing up liquid in warm water and dry thoroughly. Check that the air outlet hose is clear if you have one fitted. Check that the condenser is empty of water and the case is free from dust and lint. Vacuum / brush or wash the outside of the collector in washing up liquid and warm water and dry.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Hoover Vision HD VHC391 saying it is full of water
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Jan 12, 2009 | Hoover HDV7FM Electric Dryer
Drying clothes properly, water going on floor not container.
The tube from the lower water collector that feeds the upper is detatched or split. Take off R/H side panel as you look at machine and at the bottom you will see a spring. Behind this is the lower water tank (very small) - it has two electrical connectors on it, There should be a black plastic tube attached to the top, this is the tube that feeds the upper condenser container.
Nov 23, 2008 | Bosch Axxis WTA4400 Dryers
My Whirlpool AWZ7303 Condensor dryer wont dry the clothes. It heats up, and you can see the steam on the clothes. I think that its not extracting the moisture properly. The water collector does get full...
Your vent hose is crimped or clogged. Take hose off and see if air is coming out. Bet your dryer has been push against the wall and crimped the hose. This is the problem 8 out 10 time but if it isnt let me know. There is more tricks.
Oct 23, 2008 | Whirlpool Dryers
Dryers Logo
55 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
