Question about Sony PlayStation Portable (PSP) Console
My psp screen turns colors
My psp just flat out stop working when i turned it on and i have no money to get it fixed
My psp is distortued and Idk want to do please help!!!!
Posted on May 22, 2012
  • Sony Master
  • 2,404 Answers
The lcd screen needs to be replaced. This is one screen that I found thru amazon, the cost is relatively low, definitely less then $50 so its not to bad and as long as you know how to get into the psp then you can replace the screen:
http://www.amazon.com/PSP-Sharp-Replacement-Screen-Sony-Backlight/dp/B000QNRGJE/ref=pd_sim_t_3
Posted on Sep 03, 2009
PSP WONT TURN ON
PSP how to videos teaches you tricks about your PSP. PSP repair will show you how to fix it when something goes wrong. Hope this helps.
Jan 02, 2012 | Sony PlayStation Portable (PSP) Console
Locked/Blank PSP Screen
sounds like a classic psp bricking...sort of
Jun 09, 2010 | Sony PlayStation Portable (PSP) Console
How to fix my psp the screen wont turn on
Turn the PSP off and remove the battery and battery cover. Remove the two screws underneath the battery. Remove the other two screws on the opposite side of the battery. Remove the final screw on the bottom edge of the PSP.Grasp the PSP on both sides with each hand and pull the cover off of the PSP. Locate the button bar on the bottom front of the PSP. Use your flathead driver to lift up the left side of the button bar until it pops up off the LCD support. Lift the button bar cable tab upwards to remove the cable and remove the button bar.Insert your flat driver into the small space on the left side of the LCD screen between the the LCD housing and the LCD mounting bracket. Twist the screwdriver slightly and the mounting tabs will pop out. Gently remove the other side of the LCD after popping out the first side tabs. Bend the PSP screen all the way down until you can see the backside of the screen.
Lift up the flex cable connectors and unhook the cables that connect the screen to the PSP motherboard. The tabs are brownish in color; they are very fragile, so be gentle. Lift the PSP screen out of the housing and place to the side.Place your new PSP screen into the PSP, face down like you had the older screen after popping out the mounting tabs. Connect all of the cables from the PSP screen into the motherboard tabs. Fold the screen back into the bracket, snapping it into place. Place the button bar back onto the LCD support, connecting the last cable. Place the cover back onto the PSP and tighten screws to finish.
Apr 02, 2010 | Sony PlayStation Portable (PSP) Console
My PSP is not turning the screen on i turn on the screen
What needs to happen is the psp needs to be taken apart so you can get to the lcd to unseat and reseat the lcd cable.
If that doesn't work then the screen is bad and would need to be replaced.
Here is a tutorial on how to replace the screen but you can also use this to get the psp to the point to unseat and reseat the cable:
http://www.llamma.com/PSP/PSPTearDown.htm
Jan 06, 2010 | Sony PlayStation Portable (PSP) Console
PSP Slim - Broken Screen ?
Its the LED on the psp that is broken. The LED is the inside screen that brings the picture up onto it like an LED flatscreen tv.
It wont be covered under your sony warranty because your warranty covers you for electrical faults not accidental.
You could contact sony to see if they would fix it for a charge but to be honest the money you'd spend fixing it, you might aswell just buy a new psp
Jul 28, 2008 | Sony PlayStation Portable (PSP) Slim...
PSP
http://www.dealextreme.com/details.dx/sku.3217
if they are both the fat (old) PSP
http://www.dealextreme.com/details.dx/sku.12884
if it the slim (new) PSP
take the PSP apart (careful 2 screws are hidden uncer the bottom sticker in the batt. compartment.
use a flat screw driver and pry the broken screen out
pull the 2 flaps on the connectors of the flat and wide rib.
lift the screen out.
put the new one in connect all the connections first
snap the scren in
reassemble.
done
please rate
please rate
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
My PSP was in my pocket while playing basketball and now the screen is messed up.
then there is a malfunctioning with the psp i suppose. if u just purchased it, go back to the shop and tell them there is something wrong with it. and they should repair it or if they cant they should replace it. it still should be under warranty, if not then if im not mistaken , by customer's rights we can return a good under 7 days. double check tho.
assuming u didnt drop the psp or damage it in other ways...
May 25, 2008 | Sony PlayStation Portable (PSP) Console
Psp
You may have a dead pixel on the screen. Sometimes dead pixels will seem to disappear when the screen turns a different color. The only way that I know how to fix it is to get repairs.
Apr 01, 2008 | Sony PlayStation Portable (PSP) Console
My psp wont get any color
go see a professional to fix it don't do anything to it yourself
Mar 25, 2008 | Sony PlayStation Portable (PSP) Console
PSP Screen is blank
uum just like the other guy said press bright button, hit it a couple of times, or take out the battery for a while.
Dec 04, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
101 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
