Question about Dell Latitude D600 Notebook
Bad battery or bad motherboard?
I'm a lab coordinator at an elementary school. We have 64 dell D510 latitude laptops. They are four years old and now out of warranty. The batteries started dying, I couldn't get them to hold a charge. I purchased new batteries and they would work for a few days. I was told by my IT dept that it is a bad motherboard and not a battery problem. Can this be true? How can 12 motherboards all go bad within in a few weeks. Any ideas? Thanks
Hi syungewaelte
I had the same exact problem:
1. Old battery led blinking (green or yellow)
2. New battery worked ok for I guess 2 weeks
3. New battery stopped working (not charging)
I already opened the laptop and cleaned it (nothing improved).
My new battery is a DELL original one.
I already checked all the possible parameters with no results. I think we shouls start looking for new laptops.
Sorry..
Posted on Dec 29, 2009
    Sergeant:
    Champion:
  • 208 Answers
Most Laptop batteries only lasts a couple of years under normal use. I would say four years old batteries are most likely at the end of its life. But you have to be careful when you buy replacement batteries. Some cheap imports on Ebay don't even have the same voltage as the original batteries. Did you get the batteries from Dell?
Posted on Sep 03, 2009
Testimonial: "Got the batteries from Dell. I'm still confused about the motherboard being the problem with all the computers. Thanks for your help."
  • Dell Master
  • 2,404 Answers
My idea and I've seen this alot, the dc jacks on the laptops become a tad bit loose, what happens is that the solder points on the bottom of the dc jacks crack because they dry out.
To fix that problem you would have to take apart the laptop and get the motherboard out of there and look on the bottom of the motherboard where the dc jack is and with a magnifying glass you'll see hairline cracks.
Best thing to do at that point is to resolder the solder points that hold the dc jack in place, that way its making a solid connection and then the motherboard can charge the batteries properly.
Keep in mind that this won't be the problem for all the laptops so the best thing to do is to have one battery that you know is working and test it in the laptops in question. Whichever ones don't charge the laptop you know that it could be a dc jack problem or could be a problem with the motherboard itself.
It will take time to do this but you'll definitely be able to narrow it down.
Testimonial: "I will suggest this to IT dept. Thanks so much for your help."
    Scholar:
  • 87 Answers
If the first batteries died slowly over time then yes this would suggest a depleted battery. If then the secondary batteries you bought were holding charge but didn't keep them for very long, and didn't hold a charge any more, this could be due to one of two things.
1- the supplier you bought the batteries from shortchanged you with unofficial products
2- the it dept is right and the recharge circuit on the batteries has gone, in all the laptops. Instead of buying a load of new laptops perhaps a new device to charge the batteries is in order. Battery charging stations for laptops are available. Ask your IT dept.
Nick
Testimonial: "Thanks for your help."
Dell latitude d510 has no power
Please check out the following steps to confirm the real issue:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
I think the most likely cause is that your dell charger is broken, just try a new charger to test:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Dec 04, 2012 | Dell Latitude D510 Notebook
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
Dell latitude d510 want power on
Why can't you dell latitude d510 power on?You didn't descript your dell latitude d510 problem clear even.It may be the problem of ram,graphics card ,mainboard,or dell latitude d510 battery.
May 31, 2010 | Dell Latitude D510 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Nothing is shown on my Dell Latitude D510 laptop when it is attached to power. No leds, nothing.
1st try a known good AC adapter, see if any change. 2nd, remove all drives, battery, external devices, RAM and wireless cards and see if system powers on and gives memory beep code error. If no change, replace motherboard. If you get beeps, power off, install a RAM module, see if system posts. If it does, add items till you identify the failed component. If no go, replace motherboard. Motherboards are roughly $150 on EBay
Oct 03, 2009 | Dell Latitude D510 Notebook
Wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
May 05, 2009 | Dell Latitude D510 Notebook
Ac adapter's wont charge battery or pwr. unit
I would say take to a good PC repair shop (Not Geek Squad) and ask them to look at the power jack on the motherboard, it may need replacing. Next would be more of a a motherboard problem and its just quit. Good repair shops could help you either way get it fixed. I don't recommend anyone tackling any sort of laptop motherboard fix unless you really know what your doing.
Apr 20, 2009 | Dell Latitude D510 Notebook
Flashing red light
It is an indication that the battery is beginning to fail. Portable system batteries have a useful life of approximately 300 to 500 recharge cycles on average. (Some last longer, some shorter)
If the battery is over a year old, then the warranty on the battery is expired. You'll need to purchase an new battery
Feb 26, 2009 | Dell Latitude D510 Notebook
Dell latitude d510 cannot recognise harddrive
Doesn't sound good. A bad cmos battery can cause symptoms like this (small battery inside the computer to run the clock when it is off).
Although I am afraid it is probably more like the BIOS is corrupt. Which is what is called in a bricked state. You may find info on the Internet for tricks for trying to get it unbricked, but they don't always work. :(
Jan 18, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
314 people viewed this question
Alun Cox
