Question about Kenmore 98702 Stacked Washer/Dryer
Same problem, will not drain at all or spin
How much does a pump usually cost, and is it a difficult job ?? Thanks in advance
  • 415 Answers
The front panel comes off and the pump run if an electric on 80.00-140.00 just remove 2 clamps and make sure you remove the water from the tub. but the good news is you may not have to buy a pump get you wet/dry vac handy and ready to remove the remaining water when you unhook the hose at pump from the tub once gone remove whatever is plugging then put hose back on and in spin cyc start it if you here the pump run you should be ok then try with a small amount of water put back in to spin if pumps out your good to go
Posted on Sep 03, 2009
How much would a replacement Water pump cost?
On a Dodge Stratus, you cannot just change the water pump (more properly called "coolant pump") alone, since it is powered by the timing belt, such that you need a complete set that includes the pump, the timing belt and the tensioner. If you decide to just change the pump (or the belt) alone, the other will fail soon. To find the parts cost, first find the engine that your car has, then go to Gates.com and find the replacement set that corresponds to your engine, then go to your favorite parts store and buy a matched set. But beware that changing the pump (or the belt, for that matter) IS NOT AS EASY as changing them in an older car, because the available space in the Stratus is very tight, and you will find that you have to remove many more components and a lot more disassembly just to reach the pump and belt; in other words, if you have the time, tools and available place to do a longer than usual repair, go ahead. But be warned it is much more difficult than in older Dodges, like the Spirit (which requires less than a fourth of the time to do!). So much for "advanced" designs...
amarquez514.
Nov 24, 2013 | 2004 Dodge Stratus
Told i need a new fuel pump, fuel filter and blow out injectors and battery for my 1995 850 Turbo I was quoted 1200.00. Am i being ripped off?
sounds about right..
up to $500 for the pump plus labour, which is usually 3+ hours so you're looking at $800 just for that job... then they charge you for each other job they have to do.
Sep 04, 2009 | 1995 Volvo 850
Noisy Frigidaire front load washing machine.
comming from a Sears Tech,,, ME
he is right. the main bearring is done.
the part in canada costs 149.99
the issue is USUALLY caused by poor quality of water (well water)
or improper detergent.
a "HE" type detergent must be used in this machine. or this issue will come up afer about 5 yrs.
its not too bad of a job to do, takes 1 person about 1.5 hrs.. and does cost roughly 500 to fix.
It might be worth it to go and buy a newer frontload washer that this is not as much of an issue with.
but it is not worthless to fix, providing the proper detergent is used in it all the time.
May 26, 2009 | Frigidaire Washing Machines
Toyota camry 1993 4 cyl car the hydraulic fluid line entering the pump close to the left rear wheel got rusted and is leaking,and needs replacement.Please let me know what parts will be required and what...
Brake lines are not expensive, you can purchase different diameters, and lengths at any parts store. If the line is rusted and leaking, the rest of the brake line system needs to be visually inspected, as usually when a line rusts through, the rest of the system is probably rusting away and may also need replacement.
So, although the parts are not expensive, this is a lousy labor intensive job. The lines will be rusted at connections and difficult to separate, and brake system will have to be bled to remove all air. Your safety is of the utmost importance, so get this fixed before you drive it. To fix the one line should not cost much, to replace all the brake lines could cost several hundred $. If you can do it yourself, you can save a lot, but as I said, it's a lousy job, especially if you don' have a lift to raise the car for easier access. Good luck.
Apr 16, 2009 | 1993 Toyota Camry V6
Average cost of mechanic changing oil pump on 2005 Chevy Cavalier
You are probably looking at around at least 1500 if not more
Mar 05, 2009 | 2005 Chevrolet Cavalier
Transmission repair
You are dealing with a very difficult repair job.
Figure about 28 hours labor, at your area's going labor rate, and a real Pro that is capable of rebuilding it...
This is not a job for a guy who is not trained on this..
Industry standard labor alone will run you about $2,500.00.
That is before you factor in the necessary parts that will be needed.
Personally, I would forego the overhaul option and look into a replacement. Much cheaper. Trust me.
The graciousness of a FixYa rating would be greatly appreciated. Thanks in advance.
Jan 24, 2009 | 2000 Toyota Tundra
Timimg belt on on 2003 megane
no i dont think so but you can always get a 2nd opinion on the matter and a second cost amount...
Jan 12, 2009 | 2005 Renault 18I
Leak
no, just tilt the machine back. The pump is held on by two clips, and two clamps to the hoses. Make sure it is leaking from the pump. Not very common.
Oct 22, 2008 | Kenmore 13202 Top Load Washer
Fuel pump on 1998 Explorer
I had one replaced on a 1999 Ford Explorer and it cost was Labor / Parts $884.
Sep 24, 2008 | 1998 Ford Explorer
Secodary Air Pump 2001 Beetle 1.8 Turbo
Had one changed on my daughters 1998 VW Beetle, cost nearly $650 for part plus installation. Failure came while her car was in Boston so I was unable to complete the task. The part is readily accessible in the front of the engine compartment, and not all that difficult to replace. If you can change brakes, alternators, serpentine belts, etc. you should be able to change the secondary air pump. Check with your local parts supplier like AutoZone or Murrays, they may have tips & tricks to make the job a bit easier.
Good luck, and have confidence.
Jun 08, 2008 | 2000 Volkswagen Beetle
Kenmore 98702 Stacked Washer/Dryer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
