Question about Lexmark X7350 All-In-One InkJet Printer
Lexmark x7350 all in one printer will not turn on
Lexmark x7350 all in one printer will not turn on. worked yesterday. at times will turn on but ink carrage doesn't move
Wont turn on
did you check the usb cable try another cable if not check the power cord if it dose not turn on then you need a new one
Oct 29, 2013 | Lexmark X7350 All-In-One Printer
Can u help me with resetting my Lexmark x7350? i revilled my cartridges, and now the printer says my color cardridge is allmost empty. Thank you!
Once the Lexmark cartridge is refilled, it can no longer report it's ink level. ). You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
May 24, 2011 | Lexmark X7350 All-In-One Printer
Need to know how to install ink cartridges
Perhaps the Lexmark X7350 User's Guide will be able to help you. Just click on the link to download: http://bit.ly/aSKpk4. Scroll to Maintaining the printer, Page 70, for the instructions on how to install the ink cartridges.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source.
Thank you for choosing Lexmark.
Aug 27, 2010 | Lexmark X7350 All-In-One InkJet Printer
How do you change ink cartridges in the lexmarkZ7350 all in one inkjet printer
It should have come with an instruction manual, installed a manual on your pc, and also a quick start poster.
If you dont have a copy, look here.
http://www.retrevo.com/support/Lexmark-X7350-Multifunction-Printers-manual/id/393ag924/t/2/
Jul 20, 2010 | Lexmark X7350 All-In-One InkJet Printer
A neighbor just gave me this printer...It says low
If you don't want to spend money on ink the a Lexmark is the last printer you need. It's cheaper to buy a new one!
Dec 28, 2009 | Lexmark X7350 All-In-One Printer
I ordered Lexmark 32 & 33 ink cartridges off ebay (but they are not 'genuine'). I'm getting an error message #1203 - 'Consult your user's guide'. Does my Lexmark X7350 only accept Lexmark brand...
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Nov 30, 2009 | Lexmark X7350 All-In-One InkJet Printer
Refilled cartridge , printer says right cartridge incorrect
Lexmark builds intelligence into their cartridges and printers to prevent the use of refilled cartridges.
Lexmark has never approved the use of anyone else's ink for their printers primarily because there is no way to prove the quality of the ink.
Please purchase a Lexmark cartridge.
May 09, 2009 | Lexmark X7350 All-In-One Printer
Installing ink cartridge into a modle 5400 series
try to open this link ..http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00846503&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
tnx en good day..
Apr 15, 2008 | Lexmark X7350 All-In-One InkJet Printer
Ink Cartridges
You should be able to open the printer below the scanner. The printhead should move to the center of the printer. Then you open the clips holding the cartridges and remove the old. Replacement cartridges click into the same slots. Then you secure the clips and close the printer.
Jan 28, 2008 | Lexmark X7350 All-In-One InkJet Printer
Lexark X7350
If the contacts are different, then you may have bought a damaged cartridge, or just simply the wrong cartridge and this would explain why your printer cannot recognise the cartridge. Make sure you bought the same number Lexmark cartridge as the old one. Return it to the store as a damaged cartridge if it is the exact same cartridge. Lexmark would not change the design of a working cartridge to exclude customers from using a printer.
Sep 07, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X7350 All-In-One InkJet Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
