Question about Xerox Phaser 7700 Laser Printer
Laser unit polygon motor failure
I have this same problem, has anyone found a solution and at what cost?, or do I start looking for a replacement model, any suggestions.
    Guru:
  • 110 Answers
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00. I've bought couple of them from www.iteminconline.com. They also give good customer service for free and I think 30 day return if the part is not working. hopefully this helps
Posted on Oct 29, 2009
2 Suggested Answers
  • 110 Answers
SOURCE: laser unit polygon motor failure
Posted on Oct 22, 2009
SHARP AR-M236 CALL SERVICE CODE L6-10
Hello I found this for your error code.
Code
L6-10
Description
Polygon motor lock trouble
The polygon motor does not rotate. The motor lock signal is detected for 6sec or more after the polygon motor rotates. The motor lock signal is detected for 1sec during rotation of the polygon motor.
Causes
Polygon motor unit failure Polygon motor connection, harness trouble or disconnection MCU PWB failure
I would unplug the unit for a minute and let it cool, then restart it and see if it was a temporary glitch or if the polygon motor has ceased to funtion. You might try to see if the wiring harness has come loose, otherwise you are looking for a new polygon motor.
Here is a copy of the service manual.It also suggests running a SIM 61-1.
https://www.manualslib.com/manual/1065394/Sharp-Ar-M236.html?page=100
I found a replacement motor for the machine, to give you an idea what it will cost to replace, keep in mind if you don't have the ability to replace this yourself you will have to call a repair tech to come in and do it and you may expect the cost for that to be at least the same as the motor.
http://www.precisionroller.com/motors-for-sharp-arm205/products.html
Hopefully it isn't a motor failure. Good luck.
Oct 18, 2017 | Sharp Office Equipment & Supplies
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
C4000 km 5050
stable speed within 20 s of the START
signal turning on.
Check the connection of connector YC3 on
the engine PWB and laser scanner unit, and
the continuity across the connector terminals.
Repair or replace if necessary.
Defective polygon
motor.
Replace the laser scanner unit.
Defective engine
PWB.
Replace the engine PWB and check for correct
operation.
Apr 06, 2014 | Kyocera Mita Office Equipment & Supplies
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
Xerox 7700. Paper is jamming at lower tray and bypass tray. Will print one page fine but multiple pages it stars jamming
Hello. The Error 11, polygon motor failure is usually caused by the motor controller chip going bad on the mirror motor. We found some of the contorller chips and had them replaced. The refurbished laser units can be seen at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Nov 18, 2010 | Xerox Phaser 7700 Laser Printer
Polygon moter failer ?
The polygon motor failure is referring to the Laser Unit (part# - 116-1110-00). This issue somewhat common on the Xerox 7700. Unfortunately the laser unit must be replaced and is pretty expensive (around $1000) Replacing it isn't too hard though, just remove the right side cover and unscrew the two screws on the laser unit and unplug the two cables from the laser to the engine control board. If you do decide to repair the machine iteminc.com has the part online.
Jul 02, 2010 | Xerox Phaser 7700DN Laser Printer
It is a Sharp al 1000 with error message L6 which means Polygon mirror motor not up to speed? How is this fixed and what cost?
Since the polygon motor is part of the laser unit, it would cost about $200 plus labor to replace it
Jun 14, 2010 | Sharp AL-1000 Copier
Sharp ar-m208 message
Polygon mirror motor not up to speed. Check the motor, you power supply, and the board the motor it connected to.
Sep 23, 2008 | Sharp AR-M208 All-In-One Laser Printer
Unit 11 laser polygon motor failure
Most likely, all the problems you are experiencing are being caused by a bad laser motor assembly. We can send you a motor assembly for the laser unit and you can change it out yourself, however, we will have to charge for the entire unit since it makes one laser unit worthless. You would save on shipping that way. Aligning the lasers is a little tricky, but doable. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Aug 12, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
223 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
