It has stopped responding to the remote control. This happened first back in June. The system was unplugged for about 2 months while we were away on vacation. When plugged in on our return in August it worked with remotes for a few days. Now it has stopped responding again. Do you have any suggestions??
  • 8,457 Answers
Tries change the batteries.Might just the remote is dead over the time use.U can buy a original or very close to it with this website.1-800-Remotes Factory Original.
Posted on Sep 03, 2009
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
My original remote with this model stopped working several months ago.I bought a phillips universal remote and that worked fine for several months and that stopped working.I bought a new Phillips...
The first possibility is that the new remote control is a dud out of the box. It can happen. Another possibility is that the remote sensor in the TV has failed. Then the remote is transmitting, but it's not being picked up by the TV. (The lights are on but there's nobody home.) If you can, return the new remote to the store and exchange it. Then, if the set still doesn't respond, you'll need to replace the remote sensor.
Jan 02, 2011 | Sylvania 4819LT 19" TV
Oasis airconditioner broken
Unplug the unit for about 5 minutes and then plug it back in. If it still does not respond to the remote after that something has happened to the control panel. It should take 3 minutes after the unit is unplugged and then plugged in again before the compressor starts. (Self protection circuit) You can try turning off the circuit breaker and then turning it back on again also. I believe that your unit will work fine after trying these recomendations. Good luck.
Jan 12, 2010 | Heating & Cooling
Bose 3-2-1 Remote Control stopped working
I purchased a LAZBOY universal remote (at Fred Meyers, on sale for $9.99) and after a bunch of research and trial-&-error, was able
program it with a code (1629) which works reasonably well with the
Bose 3-2-1.
I don't have all the system-level functions (which I never utilized anyway) but do have all the basics as far as power, volume, source, and CD/DVD control.
Sep 07, 2009 | Bose 3 2 1 GSX System
2-Way Remote not responding as it should
Change the battery. The 2 way remote batterys drain after about 3 months.
Mar 16, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Remote problems
Take the remote to your local Radio Shack and have it tested.. They used to carry IR cards and now have a pen-like tester that can tell if the remote is operating properly. Then, if you're sure the code is correct, you probably will have to have the IR detector in the Tv replaced...
Bill
Nov 20, 2007 | RCA RCU300WBL Remote Control
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
