Question about Mtd 22" Yard Machine Push Mower
My B&S Yard Machine shoots out white smoke it also leaks out oil and gas mixed
    Novelist:
  • 133 Answers
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
Good luck
roundo4
Posted on Sep 04, 2009
I am spraying a ton of white smoke an have a miss also dumping gas like crazy.and just changed o2 sensors
white smoke mean leaking head gasket.check engine oil look like milk shake antifreeze mixing with the oil.
Sep 23, 2013 | 1992 Lexus Sc 300
Overfill oil
Sounds like the engine is tired. Blue smoke is oil burning. Hard starting is oil on the spark plugs and/or low compression. This also can be due to someone adding too much oil.
Sometimes, the carburetor Needle valve hangs u pa bit and the Crank case oil gets mixed with gas so now the oil level is high. Too much oil in a motor is bad too, that would cause theblue smoke too.
Jul 20, 2013 | Yard Machines 11A08MB006 22Inch 139cc MTD...
Briggs & stratton intek 17.5hp smoking
check the oil see if it smells like gas if so the carb is not sealing over filling and draining into the oil a new carb can go bad or ts gas from the bad old one
Sep 20, 2012 | Yard Machines Garden
My redmax eb7001 emits white smoke while running, the more power...the more smoke
Your fuel-oil mixture has too much oil in it. The standard ratio is 40:1 which means one of the little bottles of 2-stroke oil (about 2.6 fluid ounces) is added to 1 gallon of gas. Homelite recommends a 50:1 ratio but 40:1 is better, at least in my opinion.
The last time you made the mix, did you pour the oil into the gas or did you pour the oil into a little bit of gas in the gas can, shake well and then fill it with a gallon of gas? The former can give you lots of smoke as well because it is not mixed thoroughly. The latter is the best way to mix because the agitation and the flow of gas mixes the oil better.
Other possible causes to this problem are: how old is the mix you are using? Did this mix sit all winter last and you sre using it now? If so, did you add some Stabil to the mix before storing?
Depending on your answers to the above questions, you can determine why you are getting so much white smoke.
My recommendation to you is to:
(a) Empty the blower gas tank.
(b) Mix a fresh batch of oil and gas in an approved fuel container.
(c) Pull the spark plug and inspect it, if it is black/sooty replace it.
(d) Pour the new mix into the tank and start the blower.
This should get rid of the excess smoke, if it doesn't, let me know here. Good Luck!
Oct 22, 2009 | Homelite 'Yard Broom' Leaf Blower
The exhaust is leaking a gas/oil mix
Hello;
White smoke is from coolant in the combustion chambers. Oily mix out the tailpipe is an indication of damage in the engine, and probably catastrophic at best. You need to have a mechanic check it out.
Rich
RPM Northwest
Jun 05, 2009 | 2002 Lincoln LS
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My lawn mower is spewing white smoke.
I had one in the shop that someone got their gas and kerosene cans mixed up and put kerosene in their mower it still had a little gas in it so it started up but had alot of white smoke if its blue I would tell you ,you over filled oil ,.
May 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
What is gas mixture for 3.5 hp engine?
do not put oil in gas just 87 octane gas their should be a small pulg or cap where you can ck. the oil.you do not mix gas and oil with that moter or it will smoke bad
Apr 20, 2009 | Mtd 22" Yard Machine Push Mower
What is the proper gas/oil mix ?
If you dont have your owners manual, than id try 40:1 mix. If it smokes alot than cut it back to 32:1
Dec 22, 2008 | Homelite 'Yard Broom' Leaf Blower
Mtd 22" Yard Machine Push Mower Logo
361 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
