Question about GE Refrigerators
GE TPH21PRSM Both fridge and freezer not staying cold. About 2 months ago, freezer not staying cold. I removed back freezer panel and defrosted a block of ice. I am starting on the fridge first today. What should the "W" shaped plasstic tube look like. Should it be clear, filled with fluid, or as it is, opaquish in the bottom third of both sides? If I need to remove in/out plastic tubes, is it okay to just yank them, or is there a trick to it? Thanks. Bob
  • 612 Answers
You will need to defrost again. When you do, you should see the heater at the bottom of both section of coil. They are glass tubes with a heating coil inside. I think you will find the coil broken in one or both. They are sold as a pair. ( www.partselect.com part # PS303934 @$74.41 ) Replace these. This will fix your defrost problem. If they are both good which I do think they are. You can ohm the termination thermostat, you will need to ice it down first due to it opens on the rise. It will need to be as cold as you can get it before you test it. If its good, the only thing left is the fan or timer.
P.S. the black W in the back of the fresh food section is a water restore that stores cold water for the freezer door.
Please rate solution. Thanks
Posted on Sep 03, 2009
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
I'm really pissed. Ive had my fridge fixed twice and its still doing the same thing. The freezer is not self defrosting and the fridge part is not getting cold. it was fixed profressionly two months...
Either the defrost control is bad or the heater is bad, Only two things that could be happening, ice building up on the evap. coil needs to be removed by defrosts cycles, not happening. Find a better Tech.
Jun 27, 2011 | Refrigerators
Fridge and freezer are set at 7 and the fridge is cool but not cold and the freezer has not been able to freeze a box of freezepops that have been in (2) days, The back wall of the freezer has frost...
http://www.partselect.com/PS303781-GE-WR51X10055-Defrost-Heater-Bracket-Assembly.htm?SourceCode=1&ModelNum=HSM25GFRASA
WR51X10055 is the part number of the defrost heater and bracket assembly. Item #230 in the diagram. On this unit it is a plug in unit.
It is relatively easy to replace. Remove food from the freezer section, remove shelves, remove back panel. Unplug refrigerator. Defrost the unit by either leaving the door open to the freezer section or you can hurry it up with a hair dryer. After it is defrosted, plug in the new defrost unit, plug the frigerator back in and reattach the back panel, shelves and food.
Jun 10, 2011 | Hotpoint HSM25GFRSA
My GE fridge won't stay cold. The freezer up top seems to be cold.
How to check parts
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 07, 2009 | Refrigerators
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FRidge/freezer not staying cold
i would focus on the defrost heater or heaters behind the back wall of the freezer.this is kind of common.
Aug 06, 2009 | Refrigerators
The coils under the freezer keep getting built up with solid ice so the fridge will not stay cold? Defrosted everything about a month ago when it happened the first time????
Hi, You will need to unplug the defrost drain hole located inside the freezer section under the evaporator coil. Remove the rear panel in the freezer and you can get to the drain. Please let me know if this helps you or if I can assist you further.
Vic
Jul 15, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Fridge part is not cooling; freezer is frosting up
your ref. has a defrost problem.you will need to take back panel off inside freezer and take your hair dryer again and defrost the system.then you can check your heater,thermostat which is located at top of coils that were defrosted.sometimes the thermostat will pop and not allow it to go into defrost and you need to check defrost timer.
Mar 12, 2009 | Refrigerators
GE SIDE BY SIDE FRIDGE FREEZER
Need more info on this whats is beeping? do you have any error codes, when is was plugged in... was ALL the fans blowing.. freezer fan and fan below by compressor? was there any frost on the back wall of freezer?
Aug 31, 2007 | Refrigerators
Refrigerators Logo
255 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
