Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
The water to the ice maker continues to drip then freezes up.
I have a GE Profile Refrif. Model PSC25MSWA. The water comes into the freezer then into a little tray, before running down into the ice trays. The water is freezing up in this little tray. I'm assuming that the water isn't shutting off all the way and each few drips freeze then fill up the little tray with ice, which won't allow the water to make it into the ice trys. There is also a loud noise too. I'd like to try to tackle this myself, before calling out the professionals. I appreciate any input.
  • 415 Answers
The loud noise is from the water freezing and hitting the fan blade in the freezer, is the imkr level? have you replace the filter if has one? is it hooked to an R/O water drinking system? if so remove the filter in frig. last thing to do if others questions ok if the shutoff to that water line going to frig is on the bottom of the pipe shut all the way off then turn back on if you have a dispenser and water is really slow to come out this may clear up the low water pressure. If on most units if you do not have appx 35psi it will not allow the valve inside the watervalve to seat and allows water to dribble by
Posted on Sep 03, 2009
Water drips from both ends of the ice maker ice maker. Ice maker does not appear to have a crack in. Could you tell me how to fix it? Is a GE model 3 PSC23SHMD BS
Most likely your water control valve=> WR57X10032 Water Control Valve RC This page has great instructions also. Many things can affect your ice maker so I will send this movie about ice maker related problems.
WR30X10093 Ice Maker Assembly
I will put it like this, if you can unplug the ice maker from rear wall of freezer and water continues to flow replace water valve. If only when ice maker is plugged in then the ice maker electronics and replacing the ice maker would be your best bet, Thanks, Sea Breeze
May 04, 2011 | GE Profile PSS26NGS Side by Side...
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
My freezer will not make ice after changing the
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 02, 2010 | GE Profile CustomStyle PSC23NGT Side by...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
312 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
