Question about Bosch Dishwashers
The light check water is on and everything seems ok.what should i check
  • donna303 Sep 03, 2009
    the light says "check water supply" it states in manual supply fitting jammed....but i have looked and it looks ok...says water switched should be turn on
  • 415 Answers
Its telling you to replace the water filter check you owners manual as to how to reset the light indicator
Posted on Sep 03, 2009
Frigidaire model PHSC239DSBO has no power to ice and water dispenser
I have the same problem. Also no power to the water valves or the connection at the top hinge of the freezer door. Also, nothing at the wire going to the freezer light switch. The switch is good as is the bulb. Everything else seem to be working ok. Wondering where to check next.
Mar 17, 2013 | Frigidaire PHSC239DSB Side by Side...
Everything seems to work just fine except the ice maker which stopped for no reason. I have checked everything. The water dispenser works well, the water pressure is more than sufficient. We lost power,...
I know of one trick that might solve your problem . First , make sure the lever that swings up and down during cycle is all the way down . Then , pour one eight ounce cup of water into the ice maker where the slots are . Hopefully , when the water freezes , the ice maker's sensor will detect the ice and start the dump cycle . If it does , and everything is OK inside the unit itself , it should be OK after it ejects the ice .
Oct 08, 2010 | Refrigerators
No hot water and seems no pwer. checked the fuse box, everything ok
Check behind the covers on the front of the unit, there is usually a circuit breaker button that needs to be reset.
Feb 28, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Check Water light keeps coming on and no water going in to dish washer. We have checkede all fittings and everything seems fine. Any suggestions?
Hello there:
there is a water solonoid valve that supplies the water to the unit if this has failed the valve will fail in the closed position resulting in no water to the unit so i would first check out all of the filters and than i would have the solonoid valve checked out and replaced if needed this is about a 35 dollar part ok?
best regards michael
Oct 23, 2009 | Bosch Dishwashers
Low water cooling light comes on, everything seems ok at idle.
Sounds like an air lock in the cooling system, allowing steam to build up pressure and crack the expansion tank, this also suggests the cap on the expansion tank is faulty and not releasing the pressure early enough.
Aug 14, 2009 | 1999 BMW 318 ti
Flashing low water light 98 saturn sl1
you may have a air bubble stuck in the system next to the system, or your sensor it bad, I think it maybe under the big coolant bottle
Apr 22, 2009 | 1998 Saturn SL
Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
May 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Intermittent hot water valve not opening
problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Dec 17, 2006 | Miele Novotronic W1918A Front Load Washer
Dishwashers Logo
183 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
