Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Replacing a part on a Kenmore Washer HE 3T
I need to replace one of the three grey ''Baffles'' that goes inside the tub. I know it snaps in, but I cannot figure out how to insert the screw from behind the tub.
  • 415 Answers
You shouldn't have to get from the backside the screw is at the rear of the baffle once you remove the screw the tabs slide and lock into slots push and pull and just reverse the process when installing the new one
Posted on Sep 03, 2009
Drum is so out of balance baffles are being scraped off
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Two 8182233 plastic baffles broke
This is a common problem on front loaders,Once you get the new baffles they just snap in.They have clips.
Jan 08, 2010 | Kenmore Elite 45986 Front Load Washer
How do I get change out of the washer? It went
I think you are talking about the three tub baffles that are attached to the inner tub. You can remove the baffles, usually one or two screws hold these into the tub. If it only has one screw then the opposite end is clipped into the tub. Most coins however get flushed down into the drain pump filter. We call this a coin catcher as that is what it is designed to do. Remove the front bottom panel, 3 to 4 screws on the bottom. Put a towel down under the pump to catch about a half gallon of water. There is a large round plastic screw that you unscrew from the pump assembly. The screw is three to 4 inches in diameter and almost dead center on the bottom front of the washer. Once you have unscrewed the unit, pull it out and clean out everything you see. Look inside and make sure there is nothing in the hose or the pump inlet hole. Reinstall and test for leaks before you put the panel back on. I recommend you clean this out every 6 months. Good Luck,
Appliance Specialists
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Change one baffle only or do you need to replace all three?
No as long as the baffles are screwed in properly and no other damage is present it is not important at all.
Sep 30, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore Elite front loading washer and yesterday during a load it made a terrible noise and when the washer was opened two of the fins inside the stainless steel tub had fallen off and now when...
u will need 2 replace all the baffles .remove top when this done on top of tub u will see a plug removethis . if u notice on the new baffle there is a place for a screw, that screw hole can b acessed through the hole in the top. the factory never puts these screws in the noise I dont know about. haundi24
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Broken baffles
yes they snapp right in place, it also comes with a scrw to secure them after installing, hte screwhole is acess by reomving teh top of the unit, and from there you will see a small black rubber hose leading to the top of the tub assy( from the dispensor area) after pulling that hose out of the hole, you can spinn hte tub by hand untilk you line up the baffle hole... thea prt number for the baffle kit is 8182233
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
How to replace whirlpool duet GHW9200LW baffles
easy repair, they simply slide over hte slits in the tib and firmly pull forard to snap/lock into place. there should also be a screw included in the kit, remove the top of washer (3 screws across the back of the lid)after removing hte main top toull see a black accordian like hose leading to the top of the tub assy, from the dispensor box to the left. remove this hose from the tub( pulls out of the hole), then simply turn the tub form the inside till the baffle you installed is at the 12 o'clock positon your screw hole will be right there. RESECURE THE HOSE, reassemble the top and your done!
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE 3t washer
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 40922 front load
This advice from Sears to replace baffles only applies to dryers. The baffles for the washer are installed from inside the basket. If you can't locate mounting from inside the basket, then the entire basket/tub will have to be removed and disassembled.(big job)... But I am pretty sure they mount from inside. Washer or dryer, there are three screws in the rear along the top. Remove screws, slide top toward rear and lift off.
Jun 07, 2008 | Kenmore 4292x Front Load Washer
Whirlpool duet washer has rock, marble, or something stuck inside
as long as your sure its an item between the tub assy the baffles in the drum can be removed and item fished out. but ifsomething snapped on the rear of the drum you would need to replace it. the baffle part number is 8182233, its about $40 thinknin thats worth a try before 475. the lower acess panel could also be removed and the main tub to pump hose could be removed which would give you a 3in hole to look through and try to grab somethin. worth a try
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
110 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
