Question about Milwaukee Tools & Hardware - Others
I sent my Milwaukee polisher off to get rebuilt and it came back and now runs reverse rotation? How do I fix this problem?
  • mjeys Sep 05, 2009
    I sent it out and they basically replaced everything so I am sure the field was replaced. It cost me the same price if I would have bought a new one!
  • 2,176 Answers
Did they put a field in it? I have seen some run backwards if the field it rotated 180 degrees. I would call the center that fixed it and send it back for them to repair properly. If you can give me some idea what they did I can try and trouble shoot it online for you
Posted on Sep 04, 2009
Testimonial: "I took the Makita 9227C completely apart removed the field and reassembled it after turning the field 180 degrees! Worked perfect! Thank you!"
In turbo hydro 700 why would forward gears make the rear wheels go in reverse
Your differential is upside down. Ford model T's had the same problem. It was possible to mount the rear axle upside down which made the car go forward in reverse and backward in forward gears.
Mar 07, 2015 | Cars & Trucks
MAGNET LIGHT BLINKS AND MOTOR WILL NOT TURN ON
Magnetic drills have a safety system built into them so the motor will not run unless the magnet is on and the tool is sitting on between at least 1/8-inch and 1/4-inch steel. If your drill is sitting on enough steel you may have a problem with the sensor system inside the drill. Those problems are usually electronic parts related and, most of the time, they are R&R (Remove & Replace) method is used until you fix the problem.
Jan 16, 2013 | Milwaukee Tool Milwaukee 4210-1 aka 4262-1...
Tool will not function, led flickers by trigger when attemting to use.
There is something making the motor turbine stick, i just fixed mine that was doing the same thing.
Remove the four screws holding the clutch/driver assembly on the top/front.
Use a pliers to rotate the motor gear shaft in the center of the shell until it moves freely, being careful not to damage the gear. mine was sticking in one spot so i just rotated it back and forth until it worked itself loose. There is most likely metal shavings or dirt clogging it and preventing it from rotating. I would clean any debris from inside before putting it back together and grease the moving parts if needed.
Attach a charged battery and pull the trigger in foreward and reverse positions to see if the drill works ok. Mine works like a charm now. One of my batteries is shot though, not sure if it had anything to do with the stuck motor turbine.
Dec 05, 2009 | Milwaukee Tool Milwaukee 2601 22 18V Li...
Milwaukee Polisher model 5460. Gear Case Replacement
you need to remove the pad first and then you will find 2 torx screws about a 25, remove them and the plate next if you have a dead blow hammer tap on the side of the gearcase where the screws were and the spindle assembly and bearings will jump out of the housing, then remove the 4 screws holding the gearcase to the motor housing and it will come apart. To reinsert the spindle assembly gently tap back into place with the hammer to reset the gears. Let me know if you need more assistance.
Nov 25, 2009 | Milwaukee Tool Milwaukee 5460 - 6 7/9"...
Miter saw motor is running back wards
I'd say it was the new wiring that was reversed. Motors cant really start reversing themselves on their own and the only other way it would seem reversed is if the blade was put on backwards...
So yes I think you have the wires reversed when you re-wired the cord.
Please rate this solution on FixYa!
Jun 21, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Lost cord for 5460
Contact Whitton Supply at 1800-777-5561
Apr 02, 2009 | Tools & Hardware - Others
Reverse sometimes does not engage.
Listen John, take the vehicle back to the tranny guy and tell him/her the problem. The reverse band in the tranny is obviously having a problem. They should at the least give you a deal to fix this. Good luck.
Mar 30, 2009 | 1999 Dodge Grand Caravan
Tools & Hardware - Others Logo
65 people viewed this question
Top Milwaukee Tools & Hardware - Others Experts
Joseph Mueller
Joseph Mueller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Milwaukee Tool and Hardware - Other Expert? Answer questions, earn points and help others
