Question about Canon DR-9080C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
I have a Canon 9080C scanner that works fine except for 11x17 pages.
I can get it to scan a single 11x17 page (sometimes) but in scanning more than one page, the pages get stuck half way through the machine.
I have cleaned the rollers and all other sizes scan just fine (receipt size up to 8.5x11).
  • bryan380 Oct 18, 2009
    I am using SimpleIndex as our scanner software. I have tried a few different settings but no go. I works once in a while with same settings.
  • 490 Answers
What scanning software do you use? Try downloading Captureperfect from http://software.canon-europe.com/software/0022439.asp?model= Select appropriate paper size or Scanners maximum. You can also select 'Actual size'.
S. Mohan. India
Posted on Oct 18, 2009
    President:
  • 2,306 Answers
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Posted on Sep 03, 2009
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
S. Mohan, Chennai, India
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
9080c fails to scan single page; has trouble scanning a batch.
Hi
what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
good luck.
Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
"Skip Blank Page" but still inserts one
I have two of these scanners the only way that i have found round this is to scan the pages duplex then remove the unwanted afterwards!
Aug 26, 2008 | Canon DR-9080C Path-Through Scanner
Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Jun 18, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
312 people viewed this question
old marine
old marine
