Question about Dremel Variable - Speed Multipro Rotary Tool 395
Need to know basic assembly of rotary heads of different types.
    Welcome Back:
    Visited the website for 2 consecutive days.
Kept looking, found a manual online at dremel.com
Posted on Sep 04, 2009
Industrial sewing machine has jammed, the wheel will not turn
Hello Christine, I think you do have a thread stuck between the rotary hook and the bobbin case carrier. Remove the bobbin case and bobbin. You will need to remove two small slotted head screws and remove the half circle locking ring that holds the bobbin case carrier in place. Try to wiggle the bobbin case carrier one way and than the other until it comes out of the rotary hook assembly. Don't pry too hard or you might damage the carrier and/or rotary hook assembly. Once removed, I think you will find the thread that is causing the lock up situation . Before reassembling, place a drop of oil on the bearing surfaces between the carrier and rotary hook assembly and also between the locking ring and the carrier.
Mar 07, 2014 | Sewing Machines
Need Parts List And Service Guide For Kango 990/950 Breaker
If these are the original Kango kangos then you are out of luck. They have been obsolete for many years now and no parts have been manufactured for a long time. The name was bought by DeWalt and they didn't do much with it. The Kango name is now ownd and used by Milwaukee, but there machines do differ alot from the originals. There were a few main models and the main mid sized breakers were the 900 (hammer only) and 950 (rotary hammer) There were a few facelift/variations of each (K, X and B I think) and they did use a couple of different sized seals/pistons/cylinders.
If it is one of the Milwaukee models you can look up diagrams here...
http://www.milwaukeetool.com/
Apr 24, 2012 | Hammering
My craftsman rotary tool burnt out is it the armature and bearing assembly that i need to replace
usually but take a look at the field for discoloration of the windings, if you have a volt ohms meter take a reading across the field leads and reverse the contacts and the readings should be about the same, if there is a major difference the field is probably bad also.
Aug 26, 2011 | Dremel Tools & Hardware - Others
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
I need help assembling the front forks/handlebar assembyl
The front fork slide in through the head. You must make sure that you have the headset ( a ballbearing assembly) in place. Not rusted. Make sure there is some grease in it .The pin of the fork slips through. The handlebar fits differently depending on the bicycle. Basic models fit directly on. More sophisticated models have a t-piece . There are shorter and longer extensions. They fasten with allen keys.It is actually easy to assemble.
Aug 13, 2010 | Cycling
The triangular fixing socket in the shaver head has split and the rotary head to not stay in place properly. Where can I get a new head frame?
You did not mention your shaver model number so I can not address your specific model. But, you will find many of these type parts a shaveroutlet.com. You will need to know your model number.
Feb 25, 2010 | Remington Health & Beauty
Broken Rotary Start Switch on GE Dryer (DLSR483EG4WW)
the small kink should go on one off the contacts in the switch basically its a make or break switch
Jun 24, 2009 | Dryers
Rotary tools types
Rotary tools can be divided into two types— Cut Out Tools and Basic Rotary Tools. The biggest difference between the two is the size of their motors. Cut out tools usually have larger motors.
Aug 27, 2008 | Dremel 400 Series Xpr Rotary Tool Kit with...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
140 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
