Color separation on the screen
Color separation in the picture on the screen. The picture is separating into yellow blue and red on the screen.
  • SD Tech
    SD Tech May 11, 2010
    It sounds like a convergence problem--what is brand and model number of this TV?
  • Dale Hunter May 11, 2010
    need model number if its a projection tv problem will be convergence-get back to me
  • 63 Answers
You need to have the convergance IC's replaced
Posted on Sep 03, 2009
Color separation ~ Insignia 32" NS-LCD32
1. Unplug unit from wall for 3 minutes;
2. Press & hold Power button for 1 minute;
3. Plug in unit.
OR:
1. Unplug for 3 minutes.
2. Plug in unit.
3. HOLD Power Button as unit starts ... hold until the unit flickers on then off twice.
This effectively returns the components to factory specs, much like resetting a computer. It offers a *temporary* fix, lasting 45 minutes to hours. All depends on the unit.
Mom has an Insignia 32" with the same color separation problem, which worsens as the day progresses. Best results achieved while television is cold.
Dust in the unit could contribute to the problem ... try to keep the unit dust free as possible.
Sep 16, 2012 | Insignia NS-LCD32 LCD TV
HOW TO CONNECT
You have 3 options coming out from the DVD player:
1) Composite (Yellow, White, Red)
2) S-Video (Round and Black)
3) Component (Red, Green, Blue)
Composite is the easiest, as both video and audio are taken care of through the 3 connectors.
S-Video has slightly higher quality, but is largely outdated and requires a separate audio cable.
Component has the best quality, but also requires a separate audio cable.
If you have a composite cable (it should have come with the DVD player), then just hook up the Yellow/White/Red cable from the back of the DVD player to the same color connectors on the back of your TV.
S-Video and Component connect in the same manner (respective color to respective color), but you'll need to determine whether your TV can support a separate audio input or not.
Jul 12, 2012 | Yamaha DVD-S540 DVD Player
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
Sony Projector Color Display
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
The only connections that work are the component cables(color stream, RGB-Red, Green, Blue) which I understand is a better quality picture but the connections for my DVD player are RCA (Composite - Red,...
You'll need a DVD player that has component outputs. The composite carries the entire video information, while the component sends the three different color signals separately. The red and white cables are output cables. No all DVD players have the component outputs.
Jan 27, 2010 | Hitachi 43FDX01B TV
Convergence out power supply faulty for 46gw945 picture is distorted
You can get parts for your model by going to the following link and leaving them an email stating the model of your set and indicate which board you are needing. Heres the link
http://servicemanuals.vstore.ca/
May 05, 2008 | GE 46GW945 46" Rear Projection Television
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Televison & Video Logo
291 people viewed this question
Top Televison & Video Experts
Electro Med Services...
