Question about DeLonghi Dehumidifiers
My DeLonghi DEM10 wont power on any more - like fuse gone
My DeLonghi DEM10 wont power on any more - looks like fuse has gone in the plug but it hasn't - and I checked a different power socket too - but just wont power on - no lights, nothing. Any ideas? Thanks.
  • 2 more comments
  • Simon Sep 05, 2009
    Thanks - already tried that and the unit has a light that would usually come on if the tank was full (or missing) - but no lights come on at all - it's as if the fuse has gone but it hasn't.
    I took the unit apart and there is also a small fuse on one of the PCBs - and checked this with a continuity tested and it looks OK too.
    So - both fuses seem OK - not sure what to try next.
  • ben_stark
    ben_stark Oct 14, 2012
    Hi, did you ever find out what was wrong with your DEM10? I have exactly the same problem, any advice? cheers Ben
  • Bones Martyn
    Bones Martyn Oct 27, 2012
    Hi mate, where was the fuse on the PCB please?
  • sassinuk
    sassinuk Feb 24, 2013
    Hi I got the same problem. Fuse appears to be ok on mine too. Did you ever find out what was the issue?
    President:
  • 1,382 Answers
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Posted on Sep 05, 2009
  • 3 more comments
  • Prakash R Sep 05, 2009
    There is no other option its better to take it to some authorised dealer for repair.
  • Colin Dec 07, 2013
    Totally useless comments. There's a red light flashes when the tank is full. This one is dead. If you don't know the product don't comment on it
  • Damiano Migani Nov 21, 2014
    it happened to me as well.
    it's the PCBp
    it's the PCB. You can get it from Delonghi online for £33 and do it yourself (don't know how difficult it is). I opted for having it done by autorised service centre for 55+VAT.
No lights on controls but power at theplug willnot start ?
? power at the plug, so power at the socket, but not in unit. check unit fuse in plug, check for fuses on unit, usually at back near to power inlet
Aug 13, 2014 | LG LD301EL Dehumidifier
Ebac 6200 got no power
Plug a lamp in the socket and see if it works. If it does try the unit, if it does not do anything look for a reset. If you cannot find that (there may not be one) get the schematic and trouble shoot the unit.
Feb 23, 2014 | Ebac Dehumidifiers
My des12 red light wont go off although unit is empty of water
Again!!!! Unplug machine X 15 minutes. Then fill with water. Then plug back in! If still lit, you have a water scale (mineral build up) issue that needs cleaning according to owners manual
Jan 19, 2014 | DeLonghi DE500 Dehumidifier
Runs but doesn't work (no water accumulates)
It sounds like what you hear working is the fan. The unit also has a compressor; if the compressor is bad or the freon is gone, the fan will run but the coils wont cool to remove moisture from the air.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
Delonghi dem10 not producing water
I had this problem, so have a few people. Solved by replacing big yellow capacitor on circuit board inside. Instructions here: http://www.howtomendit.com/answers.php?id=358398
May 17, 2011 | LG DH30 GoldStar Dehumidifier
My DeLonghi Portable Dehumidifier Model DEM10 has stopped working. It doesn't make the same noise when you turn it on anymore i.e the slight refridgerator sound. Does this sound like a repairable problem...
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | DeLonghi Dehumidifiers
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
Dem 10 Delonghi Dehumidifier not working
have you tried turning it to a higher setting ??
May 03, 2009 | Dehumidifiers
Dehumidifiers Logo
1,396 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
