I'm wondering, how long does SLP record on a T-90 tape. I have a T-90 VHS tape and I want to record the most I can, so I'm wondering how long SLP would record on a T-90 tape.
  • 63 Answers
SLP records 3 times longer so 270 minutes.
Posted on Sep 03, 2009
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Recording
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
Jul 19, 2009 | Toshiba W522 VHS VCR
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
Not able to copy entire vhs to dvd
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
Aug 10, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
How to set the tape lenght when recording
on older vcr's there should be a sp/slp or ep button on your remote or vcr. if not when you set a program to record, the option to choose should be there. sp= 2 hrs, ep =6 hrs.
wg
Feb 17, 2008 | Sharp VC-H810U VHS VCR
DRC 8335 Playing Back VCR Recordings in a Fast Forward State
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Jan 08, 2008 | RCA DRC8335
Speed
I assume by "last longer" you mean more record/play time.  The slp mode is the slower tape speed, which means longer record/play time.  The trade-off with the slower speed is poorer video quality.
As regards tape life, if this is what you mean- I don't know- tape life is often a matter of the quality of the tape itself.
Oct 14, 2007 | Sanyo VWM-800 VHS VCR
VCR recording
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen. SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy. HOPE this helps . . . Jaszy
May 29, 2007 | Maxell 10 Pack T60 Blank VHS Tape PI PLUS...
My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
May 27, 2007 | Daewoo DV-T8DN VHS VCR
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
