Question about Sony KP-65WV600 65" Rear Projection HDTV-Ready Television
TV cuts on and off by itself
TV keeps shutting on and off by itself...Tried different outlets, unplugged it, disconnected all other equipment, still shutting on and off by itself
  • Dale Hunter May 11, 2010
    when it cuts off how many times does the lite blink-let me know
  • 59 Answers
How often does this happen ? is it tripping random
look at the power supply panel for dry joints especially around the transformers etc
Posted on Sep 03, 2009
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
Television
Try unplugging it from the outlet for a 5 minutes, and try again. If that doesn't work - try plugging in a lamp to the outlet to make sure it works. You can also try connecting the TV to a different outlet (check fuses or circuit breakers). If you use a remote - change the batteries - or try using the power switch on the TV itself.
If it doesnt work - provide the brand and model of your TV.
Apr 11, 2014 | RCA Televison & Video
RCA LED42C45RQ 42" LED LCD HDTV Shutting Off by itself
These flat panel tv's from china have cheap capacitors. Check to see if any capacitors have pushed up top, this indicates blown or dry capacitor. Replace with exact value, in the power supply area (is where they go bad). TV has a monitoring circuit, and if standby (or ready voltage) is not adequate, tv will shut off or stay in standby mode. Little tired today, so hope that gives you an adequate answer.
Feb 14, 2014 | RCA L37WD12 37 in. LCD HDTV
My DCT6200 cable box keeps shutting itself off and then turning back on. I have already tried resetting it by unplugging, but that has done nothing. Even after I have turned off the power and left it...
1) have you tried changing that box in that room to another and the box from the other to this room. That may give you an idea of either power or signal strength issue.
2) after it resets does a "dl" show up on the box front. if so it is trying to download a firmware/software update and everythime you power cycle it starts over.
3) turn the box off then hit select and go to option 8. there should be 4 modules enabled.
4) you may need a new box
Aug 02, 2010 | Arris DCT6200 DTV Receiver
Television will not trun properly
This sounds like a safety feature built into the television. It may be trying to protect itself from an unsafe electrical source. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly. Good luck.
Jun 19, 2008 | Da-Lite Televison & Video
Model # WF20L6 symphonic
This particular model has a history of this problem.
May 28, 2008 | Televison & Video
T.V. turns itself off
What make/model is the TV?
If it's in a cabinet or other enclosure, try taking it out - it may be overheating.
Apr 05, 2008 | Televison & Video
Power cuts out
This one would be hard to say what maybe causing it to shut down there is alot of different reasons why one will come on then shut down -poor connections ,cold solder joints ,leaky or bad capacitor you guess which one? Bad flyback transfomer! ect..ect,,,,ect call a repair shop.
Dec 29, 2007 | Panasonic PT-51HX41 51" Rear Projection...
TV comes on and shuts off after about 10 secounds
Nov 19, 2007 | Sylvania 6620LCT 20 in. EDTV-Ready LCD...
Sony KP-65WV600 65" Rear Projection HDTV-Ready Television Logo
366 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
