Ho do you tell the size of an old GE heat pump condenser by the modle number. BGWA860R3B
  • 128 Answers
If youwant to order or replace evaporator or condenser no need to tell the size you have to ask with unit model number and manufacturer ex: falcon fsd 024 .
Posted on Sep 03, 2009
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
Where is the drain pan located?
Sometimes there is no condensate.
Sometimes the drain line is clogged.
Copy following links for GE Heat Pump water heater.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
Expanded drawing of 2012 GE heat pump condensation drain reservoir
http://waterheatertimer.org/images/GE-condensate-drain-560.jpg
Clean the drain line by swinging over head.
http://waterheatertimer.org/images/Black-Bud-tubing-350.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 11, 2012 | Water Heaters
Had to replace main board and power supply, now have a heat pump error. HPF code F4.Unit is 2 years old.
Type, brand, model number of water heater is not known.
If you have GE heat pump water heater, the parts are covered after first year for defects in workmanship. Otherwise the expensive water heater is not covered if it stops working.
The risk of failure is perfect reason to avoid expensive water heaters, because all costs are energy, and these units cannot guarantee longevity, even with correct and regular maintenance.
If your new laptop computer needs a motherboard, that's red flag that the computer machine will never work correctly again. Same is true for water heaters, or any expensive digitally-controlled appliance.
Same is true for tankless water heaters and hybrid water heaters and condensing water heaters and complicated solar water heater systems.
Call the manufacturer and see what they say.
Check voltage to unit. Make sure the unit is grounded.
Post question with exact mode and brand name on professional water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 13, 2012 | General Electric Ge Appliances GEH50DNSRSA...
Mara phone nokie C5-03 cori ho gaya ha ma is ka iemi # se band karna cahta hun
goto nokia care centre and tell them k mara mobile chori ho gya hai or is ka iemi number ya hai isay band kr dyn wo usay ak din main he band kr dyn ge. Thanks
Apr 02, 2012 | Cell Phones
I need a part number for the belt and where i can buy one
Nobody can tell you the belt number or size without knowing the exact type
and make modle of the machine. Take the old belt to a repair shop or a hire
shop and they will sell you a new one. Stephen.
Oct 01, 2009 | Husqvarna Garden
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Jun 26, 2008 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
