Question about Lexar FireFly 2GB USB 2.0 JumpDrive
Flash drive is not showing or responding when plugged into the UBS port
  • superindex Dec 12, 2007
    Thanks for your reply. However none of the instructions worked.
    Any other hope?
  • gholamali Apr 09, 2008
    flash memmory 2 GB from transcend company is not working when i connect it to the only my computer but to the other computer is responding but my kingstone flash memmory is responding to my computer. what is the problem of my transcend flash memmory to my computer?
  • 165 Answers
Some flash drives have a case that is too fat to be fully inserted in usb connector of some PCs, I have has the same problem, try a short usb extension cable, worked for me.
Posted on Jul 04, 2008
    Scholar:
  • 102 Answers
How many drive letter you have on your system?
make sure your drive is inside the usb port. I assume you are running windows system. Right click on my computer, click manage, then click disk management. Can you see your flash drive there, right click over it and assign a drive letter and thats it, you should see it.
Or
disconnect any f drives which you have by simply right clicking and disconnect, your flash drive should show you right away.
Or
Install any drivers which came with the drive and you should see it.
Hope that helped!
Posted on Dec 07, 2007
  • Adnan Manzoor Dec 13, 2007
    superindex:
    Right click on my computer, properties, Hardware and then device manager, check there if your USB (Universal bus controllers) are working fine and no sign of exclamation or a cross sign over them?
    Let me know please!
Replace the ubs ports on my computer
USB IS THE CORRECT TERM TRY TO FIND AN OPEN PORT PLUG IN UNIVERSAL HUB EXPANSION PORT
Sep 09, 2015 | Toshiba Satellite Computers & Internet
TRANSFERING INFO ON TO MEMORY STICK
First you need to figure out what is wrong. Is the USB drive bad, the ports not responding or what?
If the drive works on another computer, then we check the computer. 1) Are the ports turned off for power savings (look for the Screen Saver, then the Advanced settings)) or security (check the device manager in Windows). Check that the right drivers are loaded. If auto-run is disabled for USB ports, a similar effect can be seen. Check if the drive shows up in the File Explorer. Try different ports on the computer and see if the connection is tight (if the drive wiggles in the port, good contact is missing).
I hope this helps.
(if the drive doesn't work in any computer, it may have failed. If it is under warranty, you can get it replaced. However getting the data off it will not be covered by the warranty.)
May 02, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to imput image on screen
Plug it into the UBS port, or save the picture in a USB Drive than Plug into the USB port of the TV.
Apr 17, 2010 | Samsung LN40A530 40 in. LCD TV
Does Allure ESL have a port to plug in a card reader?
I cannot find any reference to a Babylock Allure ESL.
There is a Babylock Ellure, which uses the card only and the Babylock Ellure Plus with UBS port A for a flash drive.
Mar 06, 2010 | Baby Lock Esante
Sandisk tutorial
This is hard to find unless someone and lend you one...you can get one from e-bay cheep for less than $8...I do not why you need manual for it just it should be plug and play it mean that you just put it in USB slot and go to your start computer and you should be able to see it as flash drive and use it as you like to move files or store files, etc…let me how it turns out
Sep 14, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Sep 07, 2009 | Electronics - Others
Pleomax 6gb USB Drive No Longer Recognized by My Computers
It's either the USB port, the drive electronics itself, or the USB cable.
First I'd try a different USB cable.
Apr 06, 2008 | Computers & Internet
Aspire 3610 USB ports
Device manager shows the USB port if they are attached to you notebook. And in your case they are attached. So it will show it. Now in your case the problem is in your USB. Get it changed. If it is in warranty peroid then dont u take any risk. Let it be replaced. Or give your notebook in warranty period to the company from which you bought.
Sep 26, 2007 | Acer Aspire 3610 Notebook
Lexar FireFly 2GB USB 2.0 JumpDrive Logo
181 people viewed this question
Top Lexar Electronics - Others Experts
Lawrence Oravetz
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
